Datasheet Wago 256-610/334-000 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 10/10,16 мм; 10-полюсный; CAGE CLAMP; возможность объединения
PCB TERMINAL BLOCK; PUSH-BUTTON; | |||
256-610 Wago | 525 ₽ | ||
BDW25-66-10 Siemens | по запросу | ||
256-610 Wago | по запросу |
Actuation type | Push-button, angled |
Цвет | gray |
Country of origin | CH |
Габариты: глубина | 17.2 mm / 0.677 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
GTIN | 4055143385428 |
Height | 20.1 mm / 0.791 inch |
Height from the surface | 16.1 mm / 0.634 inch |
Material group | I |
Number of Poles | 10 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10/10.16 mm / 0.394/0.4 inch |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 3.6 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 10 |
Total number of potentials | 10 |
Вес | 12.012 г |
Ширина | 102.9 mm / 4.051 inch |
Серия: 256 (100 из 282)
- 256-561 256-600 256-601 256-602 256-602/000-009/999-950 256-602/332-000 256-602/332-009/999-950 256-602/333-000 256-602/333-009/999-950 256-602/334-000 256-603 256-603/000-009/999-950 256-603/332-000 256-603/332-009/999-950 256-603/333-000 256-603/334-000 256-604 256-604/000-009/999-950 256-604/332-009/999-950 256-604/333-000 256-604/334-000 256-605 256-605/000-009/999-950 256-605/332-009/999-950 256-605/333-000 256-605/334-000 256-606 256-606/000-009/999-950 256-606/332-009/999-950 256-606/333-000 256-606/334-000 256-607 256-607/000-009/999-950 256-607/332-009/999-950 256-607/333-000 256-607/334-000 256-608 256-608/000-009/999-950 256-608/332-009/999-950 256-608/333-000 256-608/334-000 256-609 256-609/000-009/999-950 256-609/332-009/999-950 256-609/333-000 256-609/334-000 256-610 256-610/000-009/999-950 256-610/332-009/999-950 256-610/333-000 256-610/334-000 256-612 256-612/000-009/999-950 256-612/332-009/999-950 256-612/333-000 256-612/334-000 256-616 256-616/000-009/999-950 256-616/332-009/999-950 256-616/334-000 256-624 256-624/000-009/999-950 256-624/332-009/999-950 256-624/334-000 256-661 256-700 256-740 256-742 256-742/332-000 256-743 256-743/332-000 256-743/332-000/999-950 256-743/999-950 256-744 256-744/332-000 256-745 256-746 256-746/332-000 256-747 256-747/332-000 256-748 256-750 256-752 256-752/332-000 256-753 256-753/332-000 256-753/332-000/999-950 256-753/999-950 256-754 256-756 256-756/332-000 256-757 256-757/332-000 256-760 256-762 256-762/332-000 256-763 256-763/332-000 256-763/332-000/999-950 256-763/999-950
- PCB Interconnect
256610/334000, 256 610/334 000
