Datasheet Wago 257-408/000-009/999-950 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 5/5,08 мм; 8-полюсный; подходит для применения во взрывоопасных зонах; CAGE CLAMP; возможность объединения
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 14.2 mm / 0.559 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.133 MJ |
| GTIN | 4017332629027 |
| Height | 24.4 mm / 0.961 inch |
| Height from the surface | 20.4 mm / 0.803 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 8 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 5/5.08 mm / 0.197/0.2 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current (Ex e II) | 16 A |
| Rated voltage EN (Ex e II) | 176 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 8 |
| Total number of potentials | 8 |
| Вес | 9.399 г |
| Ширина | 42.9 mm / 1.689 inch |
Серия: 257 (100 из 245)
- 257-100 257-200 257-300 257-400 257-401 257-402 257-402/000-009/999-950 257-402/333-000 257-403 257-403/000-009/999-950 257-403/333-000 257-404 257-404/000-009/999-950 257-404/333-000 257-405 257-405/000-012 257-405/333-000 257-406 257-406/000-009/999-950 257-406/333-000 257-407 257-407/000-009/999-950 257-407/333-000 257-408 257-408/000-006 257-408/000-009/999-950 257-408/333-000 257-409 257-409/000-009/999-950 257-409/333-000 257-410 257-410/000-009/999-950 257-410/333-000 257-412 257-412/000-009/999-950 257-412/333-000 257-416 257-416/000-009/999-950 257-416/333-000 257-424 257-424/000-009/999-950 257-436 257-436/000-009/999-950 257-448 257-448/000-009/999-950 257-451 257-452 257-452/000-009/999-950 257-453 257-453/000-009/999-950 257-454 257-454/000-009/999-950 257-455 257-455/000-009/999-950 257-456 257-456/000-009/999-950 257-457 257-457/000-009/999-950 257-458 257-458/000-009/999-950 257-459 257-459/000-009/999-950 257-460 257-460/000-009/999-950 257-462 257-462/000-009/999-950 257-466 257-466/000-009/999-950 257-474 257-474/000-009/999-950 257-486 257-486/000-009/999-950 257-498 257-498/000-009/999-950 257-500 257-501 257-502 257-502/000-009/999-950 257-502/333-000 257-503 257-503/000-009/999-950 257-503/333-000 257-504 257-504/000-009/999-950 257-504/333-000 257-505 257-505/000-009/999-950 257-505/333-000 257-506 257-506/000-009/999-950 257-506/333-000 257-507 257-507/000-009/999-950 257-507/333-000 257-508 257-508/000-009/999-950 257-508/333-000 257-509 257-509/000-009/999-950 257-509/333-000
- PCB Interconnect
257408/000009/999950, 257 408/000 009/999 950
