Datasheet Wago 257-504 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 7,5/7,62 мм; 4-полюсный; CAGE CLAMP; возможность объединения
| 5 предложений от 5 поставщиков Blade Terminal & Special Purpose Fuses -Low Voltage | |||
| GWS257504 BRADY | 956 ₽ | ||
| 257-504/333-000 Wago | по запросу | ||
| 257-504 Littelfuse | по запросу | ||
| 25.7504 | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 14.2 mm / 0.559 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.101 MJ |
| GTIN | 4044918676847 |
| Height | 24.4 mm / 0.961 inch |
| Height from the surface | 20.4 mm / 0.803 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 4 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
| Product Group | 4 (Printed Circuit) |
| Rated current | 24 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 400 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 4 |
| Total number of potentials | 4 |
| Вес | 5.704 г |
| Ширина | 32.9 mm / 1.295 inch |
Серия: 257 (100 из 245)
- 257-410/333-000 257-412 257-412/000-009/999-950 257-412/333-000 257-416 257-416/000-009/999-950 257-416/333-000 257-424 257-424/000-009/999-950 257-436 257-436/000-009/999-950 257-448 257-448/000-009/999-950 257-451 257-452 257-452/000-009/999-950 257-453 257-453/000-009/999-950 257-454 257-454/000-009/999-950 257-455 257-455/000-009/999-950 257-456 257-456/000-009/999-950 257-457 257-457/000-009/999-950 257-458 257-458/000-009/999-950 257-459 257-459/000-009/999-950 257-460 257-460/000-009/999-950 257-462 257-462/000-009/999-950 257-466 257-466/000-009/999-950 257-474 257-474/000-009/999-950 257-486 257-486/000-009/999-950 257-498 257-498/000-009/999-950 257-500 257-501 257-502 257-502/000-009/999-950 257-502/333-000 257-503 257-503/000-009/999-950 257-503/333-000 257-504 257-504/000-009/999-950 257-504/333-000 257-505 257-505/000-009/999-950 257-505/333-000 257-506 257-506/000-009/999-950 257-506/333-000 257-507 257-507/000-009/999-950 257-507/333-000 257-508 257-508/000-009/999-950 257-508/333-000 257-509 257-509/000-009/999-950 257-509/333-000 257-510 257-510/000-009/999-950 257-510/333-000 257-512 257-512/000-009/999-950 257-512/333-000 257-516 257-516/000-009/999-950 257-516/333-000 257-524 257-524/000-009/999-950 257-524/333-000 257-551 257-552 257-552/000-009/999-950 257-553 257-553/000-009/999-950 257-554 257-554/000-009/999-950 257-555 257-555/000-009/999-950 257-556 257-556/000-009/999-950 257-557 257-557/000-009/999-950 257-558 257-558/000-009/999-950 257-559 257-559/000-009/999-950 257-560 257-560/000-009/999-950 257-562
- PCB Interconnect
