Datasheet Wago 257-753/999-950 — Даташит
Стекируемый клеммный блок для печатных плат; кнопка; 2,5 мм²; шаг контактов 7,5/7,62 мм; 1-полюсный; подходит для применения во взрывоопасных зонах; зажим CAGE CLAMP; возможность объединения
| 257-753/999-950 Wago | по запросу | ||
| Actuation type | Push-button |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | CH |
| Габариты: глубина | 14.2 mm / 0.559 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| GTIN | 4017332628792 |
| Height | 24.4 mm / 0.961 inch |
| Height from the surface | 20.4 mm / 0.803 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 1 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 7.5/7.62 mm / 0.295/0.3 inch |
| Rated current (Ex e II) | 16 A |
| Rated voltage EN (Ex e II) | 275 В |
| Solder pin arrangement | within the terminal block, in line |
| Solder pin dimensions | 0.7 x 0.7 mm |
| Solder pin length | 4 мм |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Вес | 1.111 г |
| Ширина | 10.3 mm / 0.406 inch |
Серия: 257 (100 из 245)
- 257-604 257-604/000-009/999-950 257-604/333-000 257-605 257-605/000-009/999-950 257-605/333-000 257-606 257-606/000-009/999-950 257-606/333-000 257-607 257-607/000-009/999-950 257-607/333-000 257-608 257-608/000-009/999-950 257-608/333-000 257-609 257-609/000-009/999-950 257-610 257-610/000-009/999-950 257-610/333-000 257-612 257-612/000-009/999-950 257-612/333-000 257-616 257-616/000-009/999-950 257-616/333-000 257-624 257-624/000-009/999-950 257-624/333-000 257-651 257-652 257-652/000-009/999-950 257-653 257-653/000-009/999-950 257-654 257-654/000-009/999-950 257-655 257-655/000-009/999-950 257-656 257-656/000-009/999-950 257-657 257-657/000-009/999-950 257-658 257-658/000-009/999-950 257-659 257-659/000-009/999-950 257-660 257-660/000-009/999-950 257-662 257-662/000-009/999-950 257-666 257-666/000-009/999-950 257-674 257-674/000-009/999-950 257-700 257-740 257-742 257-743 257-743/999-950 257-744 257-746 257-747 257-750 257-752 257-753 257-753/999-950 257-754 257-756 257-757 257-760 257-762 257-763 257-763/999-950 257-764 257-766 257-767 257-801 257-811 257-821 257-840 257-842 257-843 257-843/999-950 257-844 257-846 257-847 257-850 257-852 257-853 257-853/999-950 257-854 257-856 257-857 257-860 257-862 257-863 257-863/999-950 257-864 257-866 257-867
- PCB Interconnect
257753/999950, 257 753/999 950
