Datasheet Wago 257-863 — Даташит
Стекируемый клеммный блок печатной платы; Кнопка; 2,5 мм²; Шаг контактов 10/10,16 мм; 1-полюсный; CAGE CLAMP; возможность объединения
Blade Terminal & Special Purpose Fuses -Low Voltage | |||
257-863 Wago | 63 ₽ | ||
257-863 Wago | по запросу | ||
257-863 Littelfuse | по запросу | ||
257863 | по запросу |
Actuation type | Push-button, angled |
Цвет | light gray |
Country of origin | PL |
Габариты: глубина | 14.2 mm / 0.559 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.032 MJ |
GTIN | 4044918414289 |
Height | 24.2 mm / 0.953 inch |
Height from the surface | 20.2 mm / 0.795 inch |
Material group | I |
Number of Poles | 1 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10/10.16 mm / 0.394/0.4 inch |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 630 В |
Solder pin arrangement | within the terminal block, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 1 |
Total number of potentials | 1 |
Вес | 1.625 г |
Ширина | 12.8 mm / 0.504 inch |
Серия: 257 (100 из 245)
- 257-604 257-604/000-009/999-950 257-604/333-000 257-605 257-605/000-009/999-950 257-605/333-000 257-606 257-606/000-009/999-950 257-606/333-000 257-607 257-607/000-009/999-950 257-607/333-000 257-608 257-608/000-009/999-950 257-608/333-000 257-609 257-609/000-009/999-950 257-610 257-610/000-009/999-950 257-610/333-000 257-612 257-612/000-009/999-950 257-612/333-000 257-616 257-616/000-009/999-950 257-616/333-000 257-624 257-624/000-009/999-950 257-624/333-000 257-651 257-652 257-652/000-009/999-950 257-653 257-653/000-009/999-950 257-654 257-654/000-009/999-950 257-655 257-655/000-009/999-950 257-656 257-656/000-009/999-950 257-657 257-657/000-009/999-950 257-658 257-658/000-009/999-950 257-659 257-659/000-009/999-950 257-660 257-660/000-009/999-950 257-662 257-662/000-009/999-950 257-666 257-666/000-009/999-950 257-674 257-674/000-009/999-950 257-700 257-740 257-742 257-743 257-743/999-950 257-744 257-746 257-747 257-750 257-752 257-753 257-753/999-950 257-754 257-756 257-757 257-760 257-762 257-763 257-763/999-950 257-764 257-766 257-767 257-801 257-811 257-821 257-840 257-842 257-843 257-843/999-950 257-844 257-846 257-847 257-850 257-852 257-853 257-853/999-950 257-854 257-856 257-857 257-860 257-862 257-863 257-863/999-950 257-864 257-866 257-867
- PCB Interconnect
