Datasheet Wago 713-1104/000-9037 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; прямая маркировка; 1,5; Шаг контактов 3,5 мм; 8-пол.
| 1-CONDUCTOR FEMALE CONNECTOR, 2- | |||
| 713-1104/000-9037 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | black |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 16 mm / 0.63 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| Fire load | 0.067 MJ |
| GTIN | 4050821176596 |
| Height | 18.8 mm / 0.74 inch |
| Insulating material | Glass fiber-reinforced polyamide (PA 66 GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | II |
| Mismating protection | Yes |
| Number of Poles | 8 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 8 |
| Total number of potentials | 8 |
| Вес | 4.33 г |
| Ширина | 15.5 mm / 0.61 inch |
Серия: 713 (100 из 548)
- 713-1103 713-1103/000-047 713-1103/000-9037 713-1103/032-047 713-1103/032-9037 713-1103/037-000 713-1103/037-047 713-1103/037-047/032-000 713-1103/037-9037 713-1103/037-9037/032-000 713-1103/107-000 713-1103/107-047 713-1103/107-047/032-000 713-1103/107-9037 713-1103/107-9037/032-000 713-1104 713-1104/000-047 713-1104/000-9037 713-1104/032-047 713-1104/032-9037 713-1104/037-000 713-1104/037-047 713-1104/037-047/032-000 713-1104/037-9037 713-1104/037-9037/032-000 713-1104/107-000 713-1104/107-047 713-1104/107-047/032-000 713-1104/107-9037 713-1104/107-9037/032-000 713-1105 713-1105/000-047 713-1105/000-9037 713-1105/032-047 713-1105/032-9037 713-1105/036-000 713-1105/037-000 713-1105/037-000/036-000 713-1105/037-047 713-1105/037-9037 713-1105/037-9037/032-000 713-1105/107-000 713-1105/107-000/036-000 713-1105/107-047 713-1105/107-9037 713-1105/107-9037/032-000 713-1106 713-1106/000-047 713-1106/000-9037 713-1106/032-047 713-1106/032-9037 713-1106/037-000 713-1106/037-047 713-1106/037-9037 713-1106/037-9037/032-000 713-1106/107-000 713-1106/107-000/036-000 713-1106/107-047 713-1106/107-9037 713-1106/107-9037/032-000 713-1107 713-1107/000-047 713-1107/000-9037 713-1107/033-047 713-1107/033-9037 713-1107/037-000 713-1107/037-047 713-1107/037-047/033-000 713-1107/037-9037 713-1107/037-9037/033-000 713-1107/107-000 713-1107/107-047 713-1107/107-047/033-000 713-1107/107-9037 713-1107/107-9037/033-000 713-1108 713-1108/000-047 713-1108/000-9037 713-1108/033-047 713-1108/033-9037 713-1108/037-000 713-1108/037-047 713-1108/037-047/033-000 713-1108/037-9037 713-1108/037-9037/033-000 713-1108/107-000 713-1108/107-047 713-1108/107-047/033-000 713-1108/107-9037 713-1108/107-9037/033-000 713-1109 713-1109/000-047 713-1109/000-9037 713-1109/033-047 713-1109/033-9037 713-1109/037-000 713-1109/037-047 713-1109/037-047/033-000 713-1109/037-9037 713-1109/037-9037/033-000
7131104/0009037, 713 1104/000 9037
