Datasheet Wago 713-1110/037-9037 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Рычаги; прямая маркировка; 1,5; Шаг контактов 3,5 мм; 20-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 713-1110/037-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | black |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 16 mm / 0.63 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| Fire load | 0.18 MJ |
| GTIN | 4050821177258 |
| Height | 18.8 mm / 0.74 inch |
| Insulating material | Glass fiber-reinforced polyamide (PA 66 GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Locking lever |
| Material group | II |
| Mismating protection | Yes |
| Number of Poles | 20 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 20 |
| Total number of potentials | 20 |
| Вес | 11.18 г |
| Ширина | 43.5 mm / 1.713 inch |
Серия: 713 (100 из 548)
- 713-1107/033-047 713-1107/033-9037 713-1107/037-000 713-1107/037-047 713-1107/037-047/033-000 713-1107/037-9037 713-1107/037-9037/033-000 713-1107/107-000 713-1107/107-047 713-1107/107-047/033-000 713-1107/107-9037 713-1107/107-9037/033-000 713-1108 713-1108/000-047 713-1108/000-9037 713-1108/033-047 713-1108/033-9037 713-1108/037-000 713-1108/037-047 713-1108/037-047/033-000 713-1108/037-9037 713-1108/037-9037/033-000 713-1108/107-000 713-1108/107-047 713-1108/107-047/033-000 713-1108/107-9037 713-1108/107-9037/033-000 713-1109 713-1109/000-047 713-1109/000-9037 713-1109/033-047 713-1109/033-9037 713-1109/037-000 713-1109/037-047 713-1109/037-047/033-000 713-1109/037-9037 713-1109/037-9037/033-000 713-1109/107-000 713-1109/107-047 713-1109/107-047/033-000 713-1109/107-9037 713-1109/107-9037/033-000 713-1110 713-1110/000-047 713-1110/000-9037 713-1110/033-047 713-1110/033-9037 713-1110/037-000 713-1110/037-047 713-1110/037-047/033-000 713-1110/037-9037 713-1110/037-9037/033-000 713-1110/107-000 713-1110/107-047 713-1110/107-047/033-000 713-1110/107-9037 713-1110/107-9037/033-000 713-1111 713-1111/000-047 713-1111/000-9037 713-1111/034-047 713-1111/034-9037 713-1111/037-000 713-1111/037-047 713-1111/037-047/034-000 713-1111/037-9037 713-1111/037-9037/034-000 713-1111/107-000 713-1111/107-047 713-1111/107-047/034-000 713-1111/107-9037 713-1111/107-9037/034-000 713-1112 713-1112/000-047 713-1112/000-9037 713-1112/034-047 713-1112/034-9037 713-1112/037-000 713-1112/037-047 713-1112/037-047/034-000 713-1112/037-9037 713-1112/037-9037/034-000 713-1112/107-000 713-1112/107-047 713-1112/107-047/034-000 713-1112/107-9037 713-1112/107-9037/034-000 713-1113 713-1113/000-047 713-1113/000-9037 713-1113/034-047 713-1113/034-9037 713-1113/037-000 713-1113/037-047 713-1113/037-047/034-000 713-1113/037-9037 713-1113/037-9037/034-000 713-1113/107-000 713-1113/107-047 713-1113/107-047/034-000
7131110/0379037, 713 1110/037 9037
