Datasheet Wago 713-1112/107-047 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Винтовой фланец; прямая маркировка; 1,5; Шаг контактов 3,5 мм; 24-пол.
Купить 713-1112/107 на РадиоЛоцман.Цены — от 4 016 до 9 725 ₽12 предложений от 4 поставщиков 1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 713-1112/107-000 | от 4 016 ₽ | ||
| 713-1112/107-000 Wago | от 4 360 ₽ | ||
| 713-1112/107-000 Wago | 9 725 ₽ | ||
| 713-1112/107-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | black |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 16 mm / 0.63 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| Fire load | 0.185 MJ |
| GTIN | 4050821177739 |
| Height | 18.8 mm / 0.74 inch |
| Insulating material | Glass fiber-reinforced polyamide (PA 66 GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Screw flange |
| Material group | II |
| Mismating protection | Yes |
| Number of Poles | 24 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 24 |
| Total number of potentials | 24 |
| Вес | 12.85 г |
| Ширина | 52.1 mm / 2.051 inch |
Серия: 713 (100 из 548)
- 713-1109/037-047 713-1109/037-047/033-000 713-1109/037-9037 713-1109/037-9037/033-000 713-1109/107-000 713-1109/107-047 713-1109/107-047/033-000 713-1109/107-9037 713-1109/107-9037/033-000 713-1110 713-1110/000-047 713-1110/000-9037 713-1110/033-047 713-1110/033-9037 713-1110/037-000 713-1110/037-047 713-1110/037-047/033-000 713-1110/037-9037 713-1110/037-9037/033-000 713-1110/107-000 713-1110/107-047 713-1110/107-047/033-000 713-1110/107-9037 713-1110/107-9037/033-000 713-1111 713-1111/000-047 713-1111/000-9037 713-1111/034-047 713-1111/034-9037 713-1111/037-000 713-1111/037-047 713-1111/037-047/034-000 713-1111/037-9037 713-1111/037-9037/034-000 713-1111/107-000 713-1111/107-047 713-1111/107-047/034-000 713-1111/107-9037 713-1111/107-9037/034-000 713-1112 713-1112/000-047 713-1112/000-9037 713-1112/034-047 713-1112/034-9037 713-1112/037-000 713-1112/037-047 713-1112/037-047/034-000 713-1112/037-9037 713-1112/037-9037/034-000 713-1112/107-000 713-1112/107-047 713-1112/107-047/034-000 713-1112/107-9037 713-1112/107-9037/034-000 713-1113 713-1113/000-047 713-1113/000-9037 713-1113/034-047 713-1113/034-9037 713-1113/037-000 713-1113/037-047 713-1113/037-047/034-000 713-1113/037-9037 713-1113/037-9037/034-000 713-1113/107-000 713-1113/107-047 713-1113/107-047/034-000 713-1113/107-9037 713-1113/107-9037/034-000 713-1114 713-1114/000-047 713-1114/000-9037 713-1114/034-047 713-1114/034-9037 713-1114/037-000 713-1114/037-047 713-1114/037-047/034-000 713-1114/037-9037 713-1114/037-9037/034-000 713-1114/107-000 713-1114/107-047 713-1114/107-047/034-000 713-1114/107-9037 713-1114/107-9037/034-000 713-1115 713-1115/000-047 713-1115/000-9037 713-1115/035-047 713-1115/035-9037 713-1115/037-000 713-1115/037-047 713-1115/037-047/035-000 713-1115/037-9037 713-1115/037-9037/035-000 713-1115/107-000 713-1115/107-047 713-1115/107-047/035-000 713-1115/107-9037 713-1115/107-9037/035-000 713-1116
7131112/107047, 713 1112/107 047
