Datasheet Wago 713-1118/107-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Винтовой фланец; 1,5; Шаг контактов 3,5 мм; 36-пол.
| 1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 713-1118/107-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | black |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 16 mm / 0.63 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
| Fire load | 0.267 MJ |
| GTIN | 4045454806910 |
| Height | 18.8 mm / 0.74 inch |
| Insulating material | Glass fiber-reinforced polyamide (PA 66 GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Screw flange |
| Material group | II |
| Mismating protection | Yes |
| Number of Poles | 36 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 36 |
| Total number of potentials | 36 |
| Вес | 18.74 г |
| Ширина | 73.1 mm / 2.878 inch |
Серия: 713 (100 из 548)
- 713-1115/037-000 713-1115/037-047 713-1115/037-047/035-000 713-1115/037-9037 713-1115/037-9037/035-000 713-1115/107-000 713-1115/107-047 713-1115/107-047/035-000 713-1115/107-9037 713-1115/107-9037/035-000 713-1116 713-1116/000-047 713-1116/000-9037 713-1116/035-047 713-1116/035-9037 713-1116/037-000 713-1116/037-047 713-1116/037-047/035-000 713-1116/037-9037 713-1116/037-9037/035-000 713-1116/107-000 713-1116/107-047 713-1116/107-047/035-000 713-1116/107-9037 713-1116/107-9037/035-000 713-1117 713-1117/000-047 713-1117/000-9037 713-1117/035-047 713-1117/035-9037 713-1117/037-000 713-1117/037-047 713-1117/037-047/035-000 713-1117/037-9037 713-1117/037-9037/035-000 713-1117/107-000 713-1117/107-047 713-1117/107-047/035-000 713-1117/107-9037 713-1117/107-9037/035-000 713-1118 713-1118/000-047 713-1118/000-9037 713-1118/035-047 713-1118/035-9037 713-1118/037-000 713-1118/037-047 713-1118/037-047/035-000 713-1118/037-9037 713-1118/037-9037/035-000 713-1118/107-000 713-1118/107-047 713-1118/107-047/035-000 713-1118/107-9037 713-1118/107-9037/035-000 713-126 713-127 713-128 713-129 713-130 713-1403 713-1403/037-000 713-1403/105-000 713-1403/107-000 713-1403/116-000 713-1403/116-000/997-405 713-1403/117-000 713-1404 713-1404/037-000 713-1404/105-000 713-1404/107-000 713-1404/116-000 713-1404/116-000/997-406 713-1404/117-000 713-1404/117-000/997-406 713-1405 713-1405/037-000 713-1405/105-000 713-1405/107-000 713-1405/116-000 713-1405/116-000/997-406 713-1405/117-000 713-1405/117-000/997-406 713-1406 713-1406/037-000 713-1406/105-000 713-1406/105-000/997-406 713-1406/107-000 713-1406/116-000 713-1406/116-000/997-406 713-1406/117-000 713-1406/117-000/997-406 713-1407 713-1407/037-000 713-1407/105-000 713-1407/105-000/997-406 713-1407/107-000 713-1407/116-000 713-1407/116-000/997-407 713-1407/117-000
7131118/107000, 713 1118/107 000
