Datasheet Wago 713-1407/117-000 — Даташит
Вилка под пайку THR, 2-рядн.; 0.8 x 0.8 mm solder pin; прямые; 100% защита от неправильного подсоединения; Резьбовой фланец; Шаг контактов 3,5 мм; 2 x 7-полюсов
THR MALE HEADER, 2-ROW; 0.8 X 0. | |||
| 713-1407/117-000/997-407 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 13.3 mm / 0.524 inch |
| Fire load | 0.086 MJ |
| GTIN | 4050821156444 |
| Height | 15.9 mm / 0.626 inch |
| Height from the surface | 13.5 mm / 0.531 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Threaded flange |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 14 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Pin spacing | 3.5 mm (0.138 inch) |
| Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 0.8 x 0.8 mm |
| Solder pin length | 2.4 мм |
| Total number of potentials | 14 |
| Вес | 4.274 г |
| Ширина | 34.6 mm / 1.362 inch |
Серия: 713 (100 из 548)
- 713-1118/037-9037/035-000 713-1118/107-000 713-1118/107-047 713-1118/107-047/035-000 713-1118/107-9037 713-1118/107-9037/035-000 713-126 713-127 713-128 713-129 713-130 713-1403 713-1403/037-000 713-1403/105-000 713-1403/107-000 713-1403/116-000 713-1403/116-000/997-405 713-1403/117-000 713-1404 713-1404/037-000 713-1404/105-000 713-1404/107-000 713-1404/116-000 713-1404/116-000/997-406 713-1404/117-000 713-1404/117-000/997-406 713-1405 713-1405/037-000 713-1405/105-000 713-1405/107-000 713-1405/116-000 713-1405/116-000/997-406 713-1405/117-000 713-1405/117-000/997-406 713-1406 713-1406/037-000 713-1406/105-000 713-1406/105-000/997-406 713-1406/107-000 713-1406/116-000 713-1406/116-000/997-406 713-1406/117-000 713-1406/117-000/997-406 713-1407 713-1407/037-000 713-1407/105-000 713-1407/105-000/997-406 713-1407/107-000 713-1407/116-000 713-1407/116-000/997-407 713-1407/117-000 713-1407/117-000/997-407 713-1408 713-1408/037-000 713-1408/105-000 713-1408/105-000/997-406 713-1408/107-000 713-1408/116-000 713-1408/116-000/997-407 713-1408/117-000 713-1408/117-000/997-407 713-1409 713-1409/037-000 713-1409/105-000 713-1409/105-000/997-407 713-1409/107-000 713-1409/116-000 713-1409/116-000/997-407 713-1409/117-000 713-1409/117-000/997-407 713-1410 713-1410/037-000 713-1410/105-000 713-1410/105-000/997-407 713-1410/107-000 713-1410/116-000 713-1410/116-000/997-408 713-1410/117-000 713-1410/117-000/997-408 713-1411 713-1411/037-000 713-1411/105-000 713-1411/105-000/997-407 713-1411/107-000 713-1411/116-000 713-1411/116-000/997-408 713-1411/117-000 713-1411/117-000/997-408 713-1412 713-1412/037-000 713-1412/105-000 713-1412/105-000/997-408 713-1412/107-000 713-1412/116-000 713-1412/116-000/997-408 713-1412/117-000 713-1412/117-000/997-408 713-1413 713-1413/037-000 713-1413/105-000
7131407/117000, 713 1407/117 000
