Datasheet Wago 713-1416/037-000 — Даташит
Вилка THT, 2-рядн.; 0.8 x 0.8 mm solder pin; прямые; 100% защита от неправильного подсоединения; Рычаги; Шаг контактов 3,5 мм; 2 x 16-полюсов
THT MALE HEADER, 2-ROW; 0.8 X 0. | |||
| 713-1416/037-000 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 13.3 mm / 0.524 inch |
| Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
| Fire load | 0.17 MJ |
| GTIN | 4045454808501 |
| Height | 17.3 mm / 0.681 inch |
| Height from the surface | 13.5 mm / 0.531 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Locking lever |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 32 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 0.8 x 0.8 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 3 |
| Вес | 8.274 г |
| Ширина | 64.1 mm / 2.524 inch |
Серия: 713 (100 из 548)
- 713-1410/116-000 713-1410/116-000/997-408 713-1410/117-000 713-1410/117-000/997-408 713-1411 713-1411/037-000 713-1411/105-000 713-1411/105-000/997-407 713-1411/107-000 713-1411/116-000 713-1411/116-000/997-408 713-1411/117-000 713-1411/117-000/997-408 713-1412 713-1412/037-000 713-1412/105-000 713-1412/105-000/997-408 713-1412/107-000 713-1412/116-000 713-1412/116-000/997-408 713-1412/117-000 713-1412/117-000/997-408 713-1413 713-1413/037-000 713-1413/105-000 713-1413/105-000/997-408 713-1413/107-000 713-1413/116-000 713-1413/116-000/997-408 713-1413/117-000 713-1413/117-000/997-408 713-1414 713-1414/037-000 713-1414/105-000 713-1414/105-000/997-408 713-1414/107-000 713-1414/116-000 713-1414/116-000/997-408 713-1414/117-000 713-1414/117-000/997-408 713-1415 713-1415/037-000 713-1415/105-000 713-1415/105-000/997-408 713-1415/107-000 713-1415/116-000 713-1415/116-000/997-409 713-1415/117-000 713-1415/117-000/997-409 713-1416 713-1416/037-000 713-1416/105-000 713-1416/105-000/997-408 713-1416/107-000 713-1416/116-000 713-1416/116-000/997-409 713-1416/117-000 713-1416/117-000/997-409 713-1417 713-1417/037-000 713-1417/105-000 713-1417/105-000/997-409 713-1417/107-000 713-1417/116-000 713-1417/116-000/997-409 713-1417/117-000 713-1417/117-000/997-409 713-1418 713-1418/037-000 713-1418/105-000 713-1418/105-000/997-409 713-1418/107-000 713-1418/116-000 713-1418/116-000/997-409 713-1418/117-000 713-1418/117-000/997-409 713-1423 713-1423/037-000 713-1423/105-000 713-1423/107-000 713-1423/116-000 713-1423/117-000 713-1424 713-1424/037-000 713-1424/105-000 713-1424/105-000/997-405 713-1424/107-000 713-1424/116-000 713-1424/116-000/997-406 713-1424/117-000 713-1424/117-000/997-406 713-1425 713-1425/037-000 713-1425/105-000 713-1425/107-000 713-1425/116-000 713-1425/116-000/997-406 713-1425/117-000 713-1425/117-000/997-406 713-1426
7131416/037000, 713 1416/037 000
