Datasheet Wago 713-1417/105-000 — Даташит
Вилка под пайку THR, 2-рядн.; 0.8 x 0.8 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 3,5 мм; 2 x 17-полюсов
THR MALE HEADER, 2-ROW0.8 X 0.8 MM SOLDER PIN STRAIGHT, BLACK | |||
| 713-1417/105-000/997-409 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 13.3 mm / 0.524 inch |
| Fire load | 0.176 MJ |
| GTIN | 4050821155805 |
| Height | 15.9 mm / 0.626 inch |
| Height from the surface | 13.5 mm / 0.531 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 34 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Pin spacing | 3.5 mm (0.138 inch) |
| Plated through-hole diameter (THR) | 1.3 (+ 0.1) мм |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 0.8 x 0.8 mm |
| Solder pin length | 2.4 мм |
| Total number of potentials | 3 |
| Вес | 8.434 г |
| Ширина | 61 mm / 2.402 inch |
Серия: 713 (100 из 548)
- 713-1411/116-000/997-408 713-1411/117-000 713-1411/117-000/997-408 713-1412 713-1412/037-000 713-1412/105-000 713-1412/105-000/997-408 713-1412/107-000 713-1412/116-000 713-1412/116-000/997-408 713-1412/117-000 713-1412/117-000/997-408 713-1413 713-1413/037-000 713-1413/105-000 713-1413/105-000/997-408 713-1413/107-000 713-1413/116-000 713-1413/116-000/997-408 713-1413/117-000 713-1413/117-000/997-408 713-1414 713-1414/037-000 713-1414/105-000 713-1414/105-000/997-408 713-1414/107-000 713-1414/116-000 713-1414/116-000/997-408 713-1414/117-000 713-1414/117-000/997-408 713-1415 713-1415/037-000 713-1415/105-000 713-1415/105-000/997-408 713-1415/107-000 713-1415/116-000 713-1415/116-000/997-409 713-1415/117-000 713-1415/117-000/997-409 713-1416 713-1416/037-000 713-1416/105-000 713-1416/105-000/997-408 713-1416/107-000 713-1416/116-000 713-1416/116-000/997-409 713-1416/117-000 713-1416/117-000/997-409 713-1417 713-1417/037-000 713-1417/105-000 713-1417/105-000/997-409 713-1417/107-000 713-1417/116-000 713-1417/116-000/997-409 713-1417/117-000 713-1417/117-000/997-409 713-1418 713-1418/037-000 713-1418/105-000 713-1418/105-000/997-409 713-1418/107-000 713-1418/116-000 713-1418/116-000/997-409 713-1418/117-000 713-1418/117-000/997-409 713-1423 713-1423/037-000 713-1423/105-000 713-1423/107-000 713-1423/116-000 713-1423/117-000 713-1424 713-1424/037-000 713-1424/105-000 713-1424/105-000/997-405 713-1424/107-000 713-1424/116-000 713-1424/116-000/997-406 713-1424/117-000 713-1424/117-000/997-406 713-1425 713-1425/037-000 713-1425/105-000 713-1425/107-000 713-1425/116-000 713-1425/116-000/997-406 713-1425/117-000 713-1425/117-000/997-406 713-1426 713-1426/037-000 713-1426/105-000 713-1426/105-000/997-406 713-1426/107-000 713-1426/116-000 713-1426/116-000/997-406 713-1426/117-000 713-1426/117-000/997-406 713-1427 713-1427/037-000
7131417/105000, 713 1417/105 000
