Datasheet Wago 713-1429/105-000/997-407 — Даташит
Вилка под пайку THR, 2-рядн.; 0.8 x 0.8 mm solder pin; угловые; 100% защита от неправильного подсоединения; упаковка в ленте на бобине; Шаг контактов 3,5 мм; 2 x 9-полюсов
THR MALE HEADER, 2-ROW 0.8 X 0.8 | |||
| 713-1429/105-000/997-407 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 13.5 mm / 0.531 inch |
| Fire load | 0.098 MJ |
| GTIN | 4050821309529 |
| Height | 15.7 mm / 0.618 inch |
| Height from the surface | 13.3 mm / 0.524 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 18 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Packaging type | bag |
| Pin spacing | 3.5 mm (0.138 inch) |
| Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Reel diameter of tape-and-reel packaging | 330 мм |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 0.8 x 0.8 mm |
| Solder pin length | 2.4 мм |
| Tape width | 56 мм |
| Total number of potentials | 18 |
| Вес | 4.979 г |
| Ширина | 33 mm / 1.299 inch |
Серия: 713 (100 из 548)
- 713-1423/107-000 713-1423/116-000 713-1423/117-000 713-1424 713-1424/037-000 713-1424/105-000 713-1424/105-000/997-405 713-1424/107-000 713-1424/116-000 713-1424/116-000/997-406 713-1424/117-000 713-1424/117-000/997-406 713-1425 713-1425/037-000 713-1425/105-000 713-1425/107-000 713-1425/116-000 713-1425/116-000/997-406 713-1425/117-000 713-1425/117-000/997-406 713-1426 713-1426/037-000 713-1426/105-000 713-1426/105-000/997-406 713-1426/107-000 713-1426/116-000 713-1426/116-000/997-406 713-1426/117-000 713-1426/117-000/997-406 713-1427 713-1427/037-000 713-1427/105-000 713-1427/105-000/997-406 713-1427/107-000 713-1427/116-000 713-1427/116-000/997-407 713-1427/117-000 713-1427/117-000/997-407 713-1428 713-1428/037-000 713-1428/105-000 713-1428/105-000/997-406 713-1428/107-000 713-1428/116-000 713-1428/116-000/997-407 713-1428/117-000 713-1428/117-000/997-407 713-1429 713-1429/037-000 713-1429/105-000 713-1429/105-000/997-407 713-1429/107-000 713-1429/116-000 713-1429/116-000/997-407 713-1429/117-000 713-1429/117-000/997-407 713-1430 713-1430/037-000 713-1430/105-000 713-1430/105-000/997-407 713-1430/107-000 713-1430/116-000 713-1430/117-000 713-1431 713-1431/037-000 713-1431/105-000 713-1431/105-000/997-407 713-1431/107-000 713-1431/116-000 713-1431/117-000 713-1432 713-1432/037-000 713-1432/105-000 713-1432/107-000 713-1432/116-000 713-1432/117-000 713-1433 713-1433/037-000 713-1433/105-000 713-1433/107-000 713-1433/116-000 713-1433/117-000 713-1434 713-1434/037-000 713-1434/105-000 713-1434/107-000 713-1434/116-000 713-1434/117-000 713-1435 713-1435/037-000 713-1435/105-000 713-1435/107-000 713-1435/116-000 713-1435/117-000 713-1436 713-1436/037-000 713-1436/105-000 713-1436/107-000 713-1436/116-000 713-1436/117-000
7131429/105000/997407, 713 1429/105 000/997 407
