Datasheet Wago 713-1477 — Даташит
Вилка THT, 2-рядн.; 0.8 x 0.8 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 3,5 мм; 2 x 17-полюсов
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 13.3 mm / 0.524 inch |
| Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
| Fire load | 0.176 MJ |
| GTIN | 4045454696269 |
| Height | 17.3 mm / 0.681 inch |
| Height from the surface | 13.5 mm / 0.531 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 34 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 250 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 0.8 x 0.8 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 3 |
| Вес | 8.638 г |
| Ширина | 61 mm / 2.402 inch |
Серия: 713 (100 из 548)
- 713-1430/107-000 713-1430/116-000 713-1430/117-000 713-1431 713-1431/037-000 713-1431/105-000 713-1431/105-000/997-407 713-1431/107-000 713-1431/116-000 713-1431/117-000 713-1432 713-1432/037-000 713-1432/105-000 713-1432/107-000 713-1432/116-000 713-1432/117-000 713-1433 713-1433/037-000 713-1433/105-000 713-1433/107-000 713-1433/116-000 713-1433/117-000 713-1434 713-1434/037-000 713-1434/105-000 713-1434/107-000 713-1434/116-000 713-1434/117-000 713-1435 713-1435/037-000 713-1435/105-000 713-1435/107-000 713-1435/116-000 713-1435/117-000 713-1436 713-1436/037-000 713-1436/105-000 713-1436/107-000 713-1436/116-000 713-1436/117-000 713-1437 713-1437/037-000 713-1437/105-000 713-1437/107-000 713-1437/116-000 713-1437/117-000 713-1438 713-1438/037-000 713-1438/105-000 713-1438/107-000 713-1438/116-000 713-1438/117-000 713-1463 713-1463/037-000 713-1463/107-000 713-1464 713-1464/037-000 713-1464/107-000 713-1465 713-1465/037-000 713-1465/107-000 713-1466 713-1466/037-000 713-1466/107-000 713-1467 713-1467/037-000 713-1467/107-000 713-1468 713-1468/037-000 713-1468/107-000 713-1469 713-1469/037-000 713-1469/107-000 713-1470 713-1470/037-000 713-1470/107-000 713-1471 713-1471/037-000 713-1471/107-000 713-1472 713-1472/037-000 713-1472/107-000 713-1473 713-1473/037-000 713-1473/107-000 713-1474 713-1474/037-000 713-1474/107-000 713-1475 713-1475/037-000 713-1475/107-000 713-1476 713-1476/037-000 713-1476/107-000 713-1477 713-1477/037-000 713-1477/107-000 713-1478 713-1478/037-000 713-1478/107-000
7131477, 713 1477
