Datasheet Wago 714-110 — Даташит
Серия714
Модель714-110
1-проводниковая розетка; Нажимная кнопка; 1,5; Шаг контактов 3,5 мм; 10-пол.
Miniature 3 mm surface mount chip-type cermet trimmer potentiometer
MS714110
Cooper Bussmann
204 ₽
3004-7141-10
Magnetrol
МосЧип
CTS Electronic Components
TradeElectronics
Wago 714-110
Actuation typePush-button
Цветblack
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина23 mm / 0.906 inch
Fine-stranded conductor0.2 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1.5 mm²
Fire load0.079 MJ
GTIN4045454858766
Height7.8 mm / 0.307 inch
Material groupI
Mismating protectionNo
Number of Poles10
Number of connection types1
Number of levels1
Rated current8 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)160 В
Solid conductor0.2 … 1.5 mm² / 24 … 16 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points10
Total number of potentials10
Вес5.81 г
Ширина35.7 mm / 1.406 inch
На английском языке: Datasheet Wago 714-110
