Datasheet Wago 714-138 — Даташит
Вилка THT; 0.8 x 0.8 mm solder pin; прямые; Шаг контактов 3,5 мм; 8-пол.
| THT MALE HEADER; 0.8 X 0.8 MM SO | |||
| 714-138 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 6.9 mm / 0.272 inch |
| Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
| Fire load | 0.036 MJ |
| GTIN | 4045454858872 |
| Height | 13.1 mm / 0.516 inch |
| Height from the surface | 9.7 mm / 0.382 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 8 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 8 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 0.8 x 0.8 mm |
| Solder pin length | 3.4 мм |
| Total number of potentials | 8 |
| Вес | 1.75 г |
| Ширина | 29.4 mm / 1.157 inch |
Серия: 714 (43)
- 714-101 714-102 714-102/000-047 714-103 714-103/000-047 714-104 714-104/000-047 714-105 714-105/000-047 714-106 714-106/000-047 714-108 714-108/000-047 714-110 714-110/000-047 714-112 714-112/000-047 714-114 714-114/000-047 714-115 714-116 714-132 714-133 714-134 714-135 714-136 714-138 714-140 714-142 714-144 714-145 714-146 714-162 714-163 714-164 714-165 714-166 714-168 714-170 714-172 714-174 714-175 714-176
