Datasheet Wago 721-112/031-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; зажимное кольцо; 2,5 мм²; Шаг контактов 5 мм; 12-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 721-112/031-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 26.45 mm / 1.041 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.32 MJ |
| GTIN | 4044918355650 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Mounting flange |
| Number of Poles | 12 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 12 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 22.024 г |
| Ширина | 74.8 mm / 2.945 inch |
Серия: 721 (100 из 504)
- 721-104/031-000 721-104/037-000 721-105/008-000 721-105/008-000/037-000 721-105/026-000 721-105/031-000 721-105/037-000 721-106/008-000 721-106/008-000/037-000 721-106/026-000 721-106/027-000 721-106/031-000 721-106/037-000 721-107/008-000 721-107/008-000/037-000 721-107/026-000 721-107/026-037 721-107/027-000 721-107/031-000 721-107/037-000 721-108/008-000 721-108/008-000/037-000 721-108/026-000 721-108/027-000 721-108/031-000 721-108/037-000 721-109/008-000 721-109/008-000/037-000 721-109/008-045 721-109/026-000 721-109/027-000 721-109/031-000 721-109/037-000 721-110/008-000 721-110/008-000/037-000 721-110/026-000 721-110/027-000 721-110/031-000 721-110/037-000 721-111/008-000 721-111/008-000/037-000 721-111/026-000 721-111/027-000 721-111/031-000 721-111/037-000 721-111/037-000/035-000 721-112/008-000 721-112/008-000/037-000 721-112/026-000 721-112/027-000 721-112/031-000 721-112/037-000 721-113/008-000 721-113/008-000/037-000 721-113/026-000 721-113/027-000 721-113/031-000 721-113/037-000 721-114/008-000 721-114/008-000/037-000 721-114/026-000 721-114/027-000 721-114/031-000 721-114/037-000 721-115/008-000 721-115/008-000/037-000 721-115/026-000 721-115/027-000 721-115/031-000 721-115/037-000 721-116/008-000 721-116/008-000/037-000 721-116/026-000 721-116/027-000 721-116/031-000 721-116/037-000 721-120/008-000 721-120/008-000/037-000 721-120/026-000 721-120/027-000 721-120/031-000 721-120/037-000 721-132/001-000 721-133/001-000 721-133/001-040 721-134/001-000 721-134/001-040 721-135/001-000 721-135/001-040 721-136/001-000 721-137/001-000 721-137/046-000 721-138/001-000 721-139/001-000 721-140/001-000 721-141/001-000 721-141/046-000 721-142/001-000 721-142/046-000 721-143/001-000
721112/031000, 721 112/031 000
