Datasheet Wago 721-143/001-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 5 мм; 13-пол.
| THT MALE HEADER, 1.0 X 1.0 MM SO | |||
| 721-143/001-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 11.4 mm / 0.449 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fire load | 0.079 MJ |
| GTIN | 4045454987190 |
| Height | 17 mm / 0.669 inch |
| Height from the surface | 12 mm / 0.472 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 13 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 13 |
| Вес | 4.294 г |
| Ширина | 68.2 mm / 2.685 inch |
Серия: 721 (100 из 504)
- 721-112/027-000 721-112/031-000 721-112/037-000 721-113/008-000 721-113/008-000/037-000 721-113/026-000 721-113/027-000 721-113/031-000 721-113/037-000 721-114/008-000 721-114/008-000/037-000 721-114/026-000 721-114/027-000 721-114/031-000 721-114/037-000 721-115/008-000 721-115/008-000/037-000 721-115/026-000 721-115/027-000 721-115/031-000 721-115/037-000 721-116/008-000 721-116/008-000/037-000 721-116/026-000 721-116/027-000 721-116/031-000 721-116/037-000 721-120/008-000 721-120/008-000/037-000 721-120/026-000 721-120/027-000 721-120/031-000 721-120/037-000 721-132/001-000 721-133/001-000 721-133/001-040 721-134/001-000 721-134/001-040 721-135/001-000 721-135/001-040 721-136/001-000 721-137/001-000 721-137/046-000 721-138/001-000 721-139/001-000 721-140/001-000 721-141/001-000 721-141/046-000 721-142/001-000 721-142/046-000 721-143/001-000 721-144/001-000 721-145/001-000 721-146/001-000 721-146/046-000 721-150/001-000 721-150/046-000 721-162/001-000 721-162/003-000 721-163/001-000 721-163/001-040 721-163/003-000 721-164/001-000 721-164/001-040 721-164/003-000 721-165/001-000 721-165/001-040 721-165/003-000 721-166/001-000 721-166/003-000 721-167/001-000 721-167/003-000 721-168/001-000 721-168/003-000 721-169/001-000 721-169/003-000 721-169/046-000 721-170/001-000 721-170/003-000 721-170/104-000 721-171/001-000 721-171/003-000 721-171/046-000 721-172/001-000 721-172/003-000 721-173/001-000 721-173/003-000 721-174/001-000 721-174/003-000 721-174/046-000 721-175/001-000 721-175/003-000 721-176/001-000 721-176/003-000 721-180/001-000 721-180/003-000 721-180/046-000 721-202/008-000 721-202/026-000 721-202/026-047
721143/001000, 721 143/001 000
