Datasheet Wago 721-208/037-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 7,5 мм; 8-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 721-208/037-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 29.6 mm / 1.165 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.32 MJ |
| GTIN | 4044918381673 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 8 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 8 |
| Total number of potentials | 8 |
| Вес | 18.4 г |
| Ширина | 74.1 mm / 2.917 inch |
Серия: 721 (100 из 504)
- 721-171/003-000 721-171/046-000 721-172/001-000 721-172/003-000 721-173/001-000 721-173/003-000 721-174/001-000 721-174/003-000 721-174/046-000 721-175/001-000 721-175/003-000 721-176/001-000 721-176/003-000 721-180/001-000 721-180/003-000 721-180/046-000 721-202/008-000 721-202/026-000 721-202/026-047 721-202/031-000 721-202/037-000 721-203/008-000 721-203/008-000/037-000 721-203/026-000 721-203/031-000 721-203/037-000 721-204/008-000 721-204/026-000 721-204/031-000 721-204/037-000 721-204/037-000/033-000 721-205/008-000 721-205/008-000/037-000 721-205/026-000 721-205/031-000 721-205/037-000 721-206/008-000 721-206/026-000 721-206/027-000 721-206/031-000 721-206/037-000 721-207/008-000 721-207/008-000/037-000 721-207/026-000 721-207/031-000 721-207/037-000 721-208/008-000 721-208/026-000 721-208/027-000 721-208/031-000 721-208/037-000 721-208/037-000/035-000 721-209/008-000 721-209/026-000 721-209/027-000 721-209/031-000 721-209/037-000 721-209/037-000/035-000 721-210/008-000 721-210/026-000 721-210/026-045 721-210/031-000 721-210/037-000 721-2102/026-000 721-2102/037-000 721-2103/026-000 721-2103/037-000 721-2104/026-000 721-2104/037-000 721-2105/026-000 721-2105/026-000/134-000 721-2105/037-000 721-2106/026-000 721-2106/026-000/134-000 721-2106/037-000 721-2107/026-000 721-2107/037-000 721-2108/026-000 721-2108/037-000 721-2109/026-000 721-2109/037-000 721-211/008-000 721-211/026-000 721-2110/026-000 721-2110/026-000/135-000 721-2110/037-000 721-2111/026-000 721-2111/037-000 721-2112/026-000 721-2112/037-000 721-2113/026-000 721-2113/037-000 721-2114/026-000 721-2114/037-000 721-2115/026-000 721-2115/037-000 721-2116/026-000 721-2116/037-000 721-212/008-000 721-212/026-000
721208/037000, 721 208/037 000
