Datasheet Wago 721-238/001-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 7,5 мм; 8-пол.
Купить 721-238/001-000 на РадиоЛоцман.Цены — от 538 до 1 911 ₽11 предложений от 4 поставщиков THT MALE HEADER; 1.0 X 1.0 MM SO | |||
| 721-238/001-000 | от 538 ₽ | ||
| 721-238/001-000 Wago | от 554 ₽ | ||
| 721-238/001-000 Wago | 1 911 ₽ | ||
| 721-238/001-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 11.4 mm / 0.449 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fire load | 0.064 MJ |
| GTIN | 4044918869362 |
| Height | 17 mm / 0.669 inch |
| Height from the surface | 12 mm / 0.472 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 8 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 8 |
| Вес | 3.164 г |
| Ширина | 60.5 mm / 2.382 inch |
Серия: 721 (100 из 504)
- 721-2110/026-000/135-000 721-2110/037-000 721-2111/026-000 721-2111/037-000 721-2112/026-000 721-2112/037-000 721-2113/026-000 721-2113/037-000 721-2114/026-000 721-2114/037-000 721-2115/026-000 721-2115/037-000 721-2116/026-000 721-2116/037-000 721-212/008-000 721-212/026-000 721-212/027-000 721-212/031-000 721-212/037-000 721-2202/026-000 721-2202/037-000 721-2203/026-000 721-2203/037-000 721-2204/026-000 721-2204/037-000 721-2205/026-000 721-2205/037-000 721-2206/026-000 721-2206/037-000 721-2207/026-000 721-2207/037-000 721-2208/026-000 721-2208/037-000 721-2209/026-000 721-2209/037-000 721-2210/026-000 721-2210/037-000 721-2211/026-000 721-2211/037-000 721-2212/026-000 721-2212/037-000 721-232/001-000 721-233/001-000 721-233/001-040 721-234/001-000 721-234/001-040 721-235/001-000 721-235/001-040 721-236/001-000 721-237/001-000 721-238/001-000 721-239/001-000 721-240/001-000 721-241/001-000 721-242/001-000 721-262/001-000 721-263/001-000 721-263/001-040 721-264/001-000 721-264/001-040 721-265/001-000 721-265/001-040 721-266/001-000 721-267/001-000 721-268/001-000 721-269/001-000 721-270/001-000 721-271/001-000 721-272/001-000 721-302/008-000 721-302/031-000 721-303/008-000 721-303/031-000 721-304/008-000 721-304/031-000 721-305/008-000 721-305/031-000 721-306/008-000 721-306/031-000 721-307/008-000 721-307/031-000 721-308/008-000 721-308/031-000 721-309/008-000 721-309/031-000 721-310/008-000 721-310/031-000 721-311/008-000 721-311/031-000 721-312/008-000 721-312/031-000 721-313/008-000 721-313/031-000 721-314/008-000 721-314/031-000 721-315/008-000 721-315/031-000 721-316/008-000 721-316/031-000 721-320/008-000
721238/001000, 721 238/001 000
