Datasheet Wago 721-336/031-000 — Даташит
1-проводниковая розетка; угловые; 100% защита от неправильного подсоединения; зажимное кольцо; 2,5 мм²; Шаг контактов 7,5 мм; 6-пол.
Индукционная плита-табурет Heidebrenner ETK-I-F 721336 предназначена для приготовления первых, вторых и третьих блюд в наплитной посуде на предприятиях общественного питания и... | |||
| ETK-I-F 721336 Heidebrenner | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Conductor entry direction to mating direction | 90 ° |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 27.25 mm / 1.073 inch |
| Design | angled, mountable |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.246 MJ |
| GTIN | 4017332747707 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 13.1 mm / 0.516 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Mounting flange |
| Number of Poles | 6 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 7 … 8 mm / 0.28 … 0.31 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Type of mounting | Panel mounting |
| Вес | 10.838 г |
| Ширина | 57.3 mm / 2.256 inch |
Серия: 721 (100 из 504)
- 721-265/001-000 721-265/001-040 721-266/001-000 721-267/001-000 721-268/001-000 721-269/001-000 721-270/001-000 721-271/001-000 721-272/001-000 721-302/008-000 721-302/031-000 721-303/008-000 721-303/031-000 721-304/008-000 721-304/031-000 721-305/008-000 721-305/031-000 721-306/008-000 721-306/031-000 721-307/008-000 721-307/031-000 721-308/008-000 721-308/031-000 721-309/008-000 721-309/031-000 721-310/008-000 721-310/031-000 721-311/008-000 721-311/031-000 721-312/008-000 721-312/031-000 721-313/008-000 721-313/031-000 721-314/008-000 721-314/031-000 721-315/008-000 721-315/031-000 721-316/008-000 721-316/031-000 721-320/008-000 721-320/031-000 721-332/008-000 721-332/031-000 721-333/008-000 721-333/031-000 721-334/008-000 721-334/031-000 721-335/008-000 721-335/031-000 721-336/008-000 721-336/031-000 721-337/008-000 721-337/031-000 721-338/008-000 721-338/031-000 721-339/008-000 721-339/031-000 721-340/008-000 721-340/031-000 721-341/008-000 721-341/031-000 721-342/008-000 721-342/031-000 721-432/001-000 721-433/001-000 721-433/001-040 721-434/001-000 721-434/001-040 721-435/001-000 721-435/001-040 721-436/001-000 721-437/001-000 721-438/001-000 721-439/001-000 721-440/001-000 721-441/001-000 721-442/001-000 721-443/001-000 721-444/001-000 721-445/001-000 721-446/001-000 721-450/001-000 721-462/001-000 721-463/001-000 721-463/001-040 721-464/001-000 721-464/001-040 721-465/001-000 721-465/001-040 721-466/001-000 721-467/001-000 721-468/001-000 721-469/001-000 721-470/001-000 721-471/001-000 721-472/001-000 721-473/001-000 721-474/001-000 721-475/001-000 721-476/001-000
721336/031000, 721 336/031 000
