Datasheet Wago 721-475/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; угловые; 100% защита от неправильного подсоединения; Шаг контактов 5 мм; 15-пол.
| 721475-4 | 304 ₽ | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fire load | 0.089 MJ |
| GTIN | 4050821005131 |
| Height | 15.2 mm / 0.598 inch |
| Height from the surface | 11.4 mm / 0.449 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 15 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 15 |
| Вес | 5.81 г |
| Ширина | 78.2 mm / 3.079 inch |
Серия: 721 (100 из 504)
- 721-335/031-000 721-336/008-000 721-336/031-000 721-337/008-000 721-337/031-000 721-338/008-000 721-338/031-000 721-339/008-000 721-339/031-000 721-340/008-000 721-340/031-000 721-341/008-000 721-341/031-000 721-342/008-000 721-342/031-000 721-432/001-000 721-433/001-000 721-433/001-040 721-434/001-000 721-434/001-040 721-435/001-000 721-435/001-040 721-436/001-000 721-437/001-000 721-438/001-000 721-439/001-000 721-440/001-000 721-441/001-000 721-442/001-000 721-443/001-000 721-444/001-000 721-445/001-000 721-446/001-000 721-450/001-000 721-462/001-000 721-463/001-000 721-463/001-040 721-464/001-000 721-464/001-040 721-465/001-000 721-465/001-040 721-466/001-000 721-467/001-000 721-468/001-000 721-469/001-000 721-470/001-000 721-471/001-000 721-472/001-000 721-473/001-000 721-474/001-000 721-475/001-000 721-476/001-000 721-480/001-000 721-602 721-602/018-000 721-602/019-000 721-602/019-042 721-602/114-000 721-603 721-603/000-042 721-603/018-000 721-603/018-042 721-603/019-000 721-603/019-042 721-603/114-000 721-603/114-040 721-603/114-042 721-604 721-604/000-042 721-604/018-000 721-604/018-042 721-604/018-042/033-000 721-604/019-000 721-604/019-042 721-604/114-000 721-604/114-040 721-604/114-042 721-605 721-605/000-042 721-605/018-000 721-605/018-042 721-605/019-000 721-605/019-042 721-605/033-000 721-605/114-000 721-605/114-040 721-605/114-042 721-606 721-606/018-000 721-606/019-000 721-606/034-000 721-606/114-000 721-607 721-607/000-044 721-607/018-000 721-607/019-000 721-607/114-000 721-608 721-608/018-000 721-608/019-000
721475/001000, 721 475/001 000
