Datasheet Wago 721-605/018-042 — Даташит
1-проводная вилка; 100% защита от неправильного подсоединения; Заземляющий контакт; Монтажные ножки; Защелкивающийся фланец; прямая маркировка; 2,5 мм²; Шаг контактов 5 мм; 5-пол.
1-CONDUCTOR MALE CONNECTOR; 100% | |||
| 721-605/018-042 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 27.5 mm / 1.083 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.142 MJ |
| GTIN | 4044918262897 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Ground function | with preceding GND contact |
| Height | 18.8 mm / 0.74 inch |
| Height from the surface | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 5 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 5 |
| Total number of potentials | 5 |
| Type of mounting | Panel mounting |
| Вес | 7.9 г |
| Ширина | 28.2 mm / 1.11 inch |
Серия: 721 (100 из 504)
- 721-444/001-000 721-445/001-000 721-446/001-000 721-450/001-000 721-462/001-000 721-463/001-000 721-463/001-040 721-464/001-000 721-464/001-040 721-465/001-000 721-465/001-040 721-466/001-000 721-467/001-000 721-468/001-000 721-469/001-000 721-470/001-000 721-471/001-000 721-472/001-000 721-473/001-000 721-474/001-000 721-475/001-000 721-476/001-000 721-480/001-000 721-602 721-602/018-000 721-602/019-000 721-602/019-042 721-602/114-000 721-603 721-603/000-042 721-603/018-000 721-603/018-042 721-603/019-000 721-603/019-042 721-603/114-000 721-603/114-040 721-603/114-042 721-604 721-604/000-042 721-604/018-000 721-604/018-042 721-604/018-042/033-000 721-604/019-000 721-604/019-042 721-604/114-000 721-604/114-040 721-604/114-042 721-605 721-605/000-042 721-605/018-000 721-605/018-042 721-605/019-000 721-605/019-042 721-605/033-000 721-605/114-000 721-605/114-040 721-605/114-042 721-606 721-606/018-000 721-606/019-000 721-606/034-000 721-606/114-000 721-607 721-607/000-044 721-607/018-000 721-607/019-000 721-607/114-000 721-608 721-608/018-000 721-608/019-000 721-608/034-000 721-608/114-000 721-609 721-609/000-034 721-609/000-044 721-609/018-000 721-609/019-000 721-609/114-000 721-610 721-610/018-000 721-610/019-000 721-610/114-000 721-611 721-611/018-000 721-611/019-000 721-611/114-000 721-612 721-612/018-000 721-612/019-000 721-612/114-000 721-613 721-613/018-000 721-613/019-000 721-613/114-000 721-614 721-614/018-000 721-614/019-000 721-614/019-000/035-000 721-614/114-000 721-615
721605/018042, 721 605/018 042
