Datasheet Wago 721-864/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; угловые; 100% защита от неправильного подсоединения; Шаг контактов 7,5 мм; 4-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
| 721-864/001-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 12 mm / 0.472 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fire load | 0.037 MJ |
| GTIN | 4044918933445 |
| Height | 15.2 mm / 0.598 inch |
| Height from the surface | 11.4 mm / 0.449 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 4 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 4 |
| Вес | 2 г |
| Ширина | 30.7 mm / 1.209 inch |
Серия: 721 (100 из 504)
- 721-604/018-000 721-604/018-042 721-604/018-042/033-000 721-604/019-000 721-604/019-042 721-604/114-000 721-604/114-040 721-604/114-042 721-605 721-605/000-042 721-605/018-000 721-605/018-042 721-605/019-000 721-605/019-042 721-605/033-000 721-605/114-000 721-605/114-040 721-605/114-042 721-606 721-606/018-000 721-606/019-000 721-606/034-000 721-606/114-000 721-607 721-607/000-044 721-607/018-000 721-607/019-000 721-607/114-000 721-608 721-608/018-000 721-608/019-000 721-608/034-000 721-608/114-000 721-609 721-609/000-034 721-609/000-044 721-609/018-000 721-609/019-000 721-609/114-000 721-610 721-610/018-000 721-610/019-000 721-610/114-000 721-611 721-611/018-000 721-611/019-000 721-611/114-000 721-612 721-612/018-000 721-612/019-000 721-612/114-000 721-613 721-613/018-000 721-613/019-000 721-613/114-000 721-614 721-614/018-000 721-614/019-000 721-614/019-000/035-000 721-614/114-000 721-615 721-615/018-000 721-615/019-000 721-615/114-000 721-616 721-616/018-000 721-616/019-000 721-616/114-000 721-620 721-620/018-000 721-620/019-000 721-620/114-000 721-832/001-000 721-833/001-000 721-833/001-040 721-834/001-000 721-834/001-040 721-835/001-000 721-835/001-040 721-836/001-000 721-837/001-000 721-838/001-000 721-839/001-000 721-840/001-000 721-841/001-000 721-842/001-000 721-862/001-000 721-863/001-000 721-863/001-040 721-864/001-000 721-864/001-040 721-865/001-000 721-865/001-040 721-866/001-000 721-867/001-000 721-868/001-000 721-869/001-000 721-870/001-000 721-871/001-000 721-872/001-000
721864/001000, 721 864/001 000
