Datasheet Wago 721-2106/037-000 — Даташит
2-проводная розетка; 100% защита от неправильного подсоединения; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 5 мм; 6-пол.
2-CONDUCTOR FEMALE CONNECTOR; 10 | |||
| 721-2106/037-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 29.8 mm / 1.173 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.267 MJ |
| GTIN | 4044918566919 |
| Height | 20.8 mm / 0.819 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 6 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 12 |
| Total number of potentials | 6 |
| Вес | 15.184 г |
| Ширина | 46.55 mm / 1.833 inch |
Серия: 721 (100 из 504)
- 721-203/031-000 721-203/037-000 721-204/008-000 721-204/026-000 721-204/031-000 721-204/037-000 721-204/037-000/033-000 721-205/008-000 721-205/008-000/037-000 721-205/026-000 721-205/031-000 721-205/037-000 721-206/008-000 721-206/026-000 721-206/027-000 721-206/031-000 721-206/037-000 721-207/008-000 721-207/008-000/037-000 721-207/026-000 721-207/031-000 721-207/037-000 721-208/008-000 721-208/026-000 721-208/027-000 721-208/031-000 721-208/037-000 721-208/037-000/035-000 721-209/008-000 721-209/026-000 721-209/027-000 721-209/031-000 721-209/037-000 721-209/037-000/035-000 721-210/008-000 721-210/026-000 721-210/026-045 721-210/031-000 721-210/037-000 721-2102/026-000 721-2102/037-000 721-2103/026-000 721-2103/037-000 721-2104/026-000 721-2104/037-000 721-2105/026-000 721-2105/026-000/134-000 721-2105/037-000 721-2106/026-000 721-2106/026-000/134-000 721-2106/037-000 721-2107/026-000 721-2107/037-000 721-2108/026-000 721-2108/037-000 721-2109/026-000 721-2109/037-000 721-211/008-000 721-211/026-000 721-2110/026-000 721-2110/026-000/135-000 721-2110/037-000 721-2111/026-000 721-2111/037-000 721-2112/026-000 721-2112/037-000 721-2113/026-000 721-2113/037-000 721-2114/026-000 721-2114/037-000 721-2115/026-000 721-2115/037-000 721-2116/026-000 721-2116/037-000 721-212/008-000 721-212/026-000 721-212/027-000 721-212/031-000 721-212/037-000 721-2202/026-000 721-2202/037-000 721-2203/026-000 721-2203/037-000 721-2204/026-000 721-2204/037-000 721-2205/026-000 721-2205/037-000 721-2206/026-000 721-2206/037-000 721-2207/026-000 721-2207/037-000 721-2208/026-000 721-2208/037-000 721-2209/026-000 721-2209/037-000 721-2210/026-000 721-2210/037-000 721-2211/026-000 721-2211/037-000 721-2212/026-000
7212106/037000, 721 2106/037 000
