Datasheet Wago 721-2205/037-000 — Даташит
2-проводная розетка; 100% защита от неправильного подсоединения; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 7,5 мм; 5-пол.
Купить 721-2205/037-000 на РадиоЛоцман.Цены — от 1 383 до 1 591 ₽11 предложений от 4 поставщиков 2-CONDUCTOR FEMALE CONNECTOR; 10 | |||
| 721-2205/037-000 Wago | от 1 383 ₽ | ||
| 721-2205/037-000 | от 1 418 ₽ | ||
| 721-2205/037-000 Wago | 1 591 ₽ | ||
| 721-2205/037-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 29.8 mm / 1.173 inch |
| Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.305 MJ |
| GTIN | 4044918567701 |
| Height | 20.8 mm / 0.819 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 5 |
| Number of connection types | 1 |
| Number of levels | 2 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
| Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 5 |
| Вес | 15.3 г |
| Ширина | 51.55 mm / 2.03 inch |
Серия: 721 (100 из 504)
- 721-210/026-045 721-210/031-000 721-210/037-000 721-2102/026-000 721-2102/037-000 721-2103/026-000 721-2103/037-000 721-2104/026-000 721-2104/037-000 721-2105/026-000 721-2105/026-000/134-000 721-2105/037-000 721-2106/026-000 721-2106/026-000/134-000 721-2106/037-000 721-2107/026-000 721-2107/037-000 721-2108/026-000 721-2108/037-000 721-2109/026-000 721-2109/037-000 721-211/008-000 721-211/026-000 721-2110/026-000 721-2110/026-000/135-000 721-2110/037-000 721-2111/026-000 721-2111/037-000 721-2112/026-000 721-2112/037-000 721-2113/026-000 721-2113/037-000 721-2114/026-000 721-2114/037-000 721-2115/026-000 721-2115/037-000 721-2116/026-000 721-2116/037-000 721-212/008-000 721-212/026-000 721-212/027-000 721-212/031-000 721-212/037-000 721-2202/026-000 721-2202/037-000 721-2203/026-000 721-2203/037-000 721-2204/026-000 721-2204/037-000 721-2205/026-000 721-2205/037-000 721-2206/026-000 721-2206/037-000 721-2207/026-000 721-2207/037-000 721-2208/026-000 721-2208/037-000 721-2209/026-000 721-2209/037-000 721-2210/026-000 721-2210/037-000 721-2211/026-000 721-2211/037-000 721-2212/026-000 721-2212/037-000 721-232/001-000 721-233/001-000 721-233/001-040 721-234/001-000 721-234/001-040 721-235/001-000 721-235/001-040 721-236/001-000 721-237/001-000 721-238/001-000 721-239/001-000 721-240/001-000 721-241/001-000 721-242/001-000 721-262/001-000 721-263/001-000 721-263/001-040 721-264/001-000 721-264/001-040 721-265/001-000 721-265/001-040 721-266/001-000 721-267/001-000 721-268/001-000 721-269/001-000 721-270/001-000 721-271/001-000 721-272/001-000 721-302/008-000 721-302/031-000 721-303/008-000 721-303/031-000 721-304/008-000 721-304/031-000 721-305/008-000
7212205/037000, 721 2205/037 000
