Datasheet Wago 722-143/039-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; 100% защита от неправильного подсоединения; Фиксирующий рычаг; Шаг контактов 5 мм; 13-пол.
| 722-143/039-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 11.6 mm / 0.457 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.224 MJ |
| GTIN | 4050821004998 |
| Height | 26.6 mm / 1.047 inch |
| Height from the surface | 21.6 mm / 0.85 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 13 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 13 |
| Вес | 12.92 г |
| Ширина | 80.8 mm / 3.181 inch |
Серия: 722 (100 из 306)
- 722-135/005-000 722-135/005-000/039-000 722-135/031-000 722-135/039-000 722-135/047-000 722-136 722-136/005-000 722-136/005-000/039-000 722-136/031-000 722-136/039-000 722-136/047-000 722-137 722-137/005-000 722-137/005-000/039-000 722-137/031-000 722-137/039-000 722-137/047-000 722-138 722-138/005-000 722-138/005-000/039-000 722-138/031-000 722-138/039-000 722-138/047-000 722-139 722-139/005-000 722-139/005-000/039-000 722-139/031-000 722-139/039-000 722-139/047-000 722-140 722-140/005-000 722-140/005-000/039-000 722-140/031-000 722-140/039-000 722-140/047-000 722-141 722-141/005-000 722-141/005-000/039-000 722-141/031-000 722-141/039-000 722-141/047-000 722-142 722-142/005-000 722-142/005-000/039-000 722-142/031-000 722-142/039-000 722-142/047-000 722-143 722-143/005-000 722-143/031-000 722-143/039-000 722-143/047-000 722-144 722-144/005-000 722-144/005-000/039-000 722-144/031-000 722-144/039-000 722-144/047-000 722-145 722-145/005-000 722-145/031-000 722-145/039-000 722-145/047-000 722-146 722-146/005-000 722-146/005-000/039-000 722-146/031-000 722-146/039-000 722-146/047-000 722-150 722-150/005-000 722-150/005-000/039-000 722-150/031-000 722-150/039-000 722-150/047-000 722-202/026-000 722-203/026-000 722-204/026-000 722-205/026-000 722-206/026-000 722-207/026-000 722-208/026-000 722-209/026-000 722-210/026-000 722-211/026-000 722-212/026-000 722-213/026-000 722-214/026-000 722-215/026-000 722-216/026-000 722-220/026-000 722-232 722-232/005-000 722-232/005-000/039-000 722-232/031-000 722-232/039-000 722-232/047-000 722-233 722-233/005-000 722-233/005-000/039-000
722143/039000, 722 143/039 000
