Datasheet Wago 722-236/031-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; 100% защита от неправильного подсоединения; зажимное кольцо; Шаг контактов 5 мм; 6-пол.
| THT FEMALE HEADER; 0.6 X 1.0 MM | |||
| 722-236/031-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.25 mm / 0.719 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.112 MJ |
| GTIN | 4044918627153 |
| Height | 16.6 mm / 0.654 inch |
| Height from the surface | 11.6 mm / 0.457 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Mounting flange |
| Number of Poles | 6 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 6 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 6.212 г |
| Ширина | 44.8 mm / 1.764 inch |
Серия: 722 (100 из 306)
- 722-146/047-000 722-150 722-150/005-000 722-150/005-000/039-000 722-150/031-000 722-150/039-000 722-150/047-000 722-202/026-000 722-203/026-000 722-204/026-000 722-205/026-000 722-206/026-000 722-207/026-000 722-208/026-000 722-209/026-000 722-210/026-000 722-211/026-000 722-212/026-000 722-213/026-000 722-214/026-000 722-215/026-000 722-216/026-000 722-220/026-000 722-232 722-232/005-000 722-232/005-000/039-000 722-232/031-000 722-232/039-000 722-232/047-000 722-233 722-233/005-000 722-233/005-000/039-000 722-233/031-000 722-233/039-000 722-233/047-000 722-234 722-234/005-000 722-234/005-000/039-000 722-234/031-000 722-234/039-000 722-234/047-000 722-235 722-235/005-000 722-235/005-000/039-000 722-235/031-000 722-235/039-000 722-235/047-000 722-236 722-236/005-000 722-236/005-000/039-000 722-236/031-000 722-236/039-000 722-236/047-000 722-237 722-237/005-000 722-237/005-000/039-000 722-237/031-000 722-237/039-000 722-237/047-000 722-238 722-238/005-000 722-238/005-000/039-000 722-238/031-000 722-238/039-000 722-238/047-000 722-239 722-239/005-000 722-239/005-000/039-000 722-239/031-000 722-239/039-000 722-239/047-000 722-240 722-240/005-000 722-240/005-000/039-000 722-240/031-000 722-240/039-000 722-240/047-000 722-241 722-241/005-000 722-241/005-000/039-000 722-241/031-000 722-241/039-000 722-241/047-000 722-242 722-242/005-000 722-242/005-000/039-000 722-242/031-000 722-242/039-000 722-242/047-000 722-243 722-243/005-000 722-243/031-000 722-243/039-000 722-243/047-000 722-244 722-244/005-000 722-244/005-000/039-000 722-244/031-000 722-244/039-000 722-244/047-000
722236/031000, 722 236/031 000
