Datasheet Wago 722-245/039-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; 100% защита от неправильного подсоединения; Фиксирующий рычаг; Шаг контактов 5 мм; 15-пол.
| 722-245/031-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.25 mm / 0.719 inch |
| Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
| Fire load | 0.254 MJ |
| GTIN | 4050821005179 |
| Height | 16.6 mm / 0.654 inch |
| Height from the surface | 11.6 mm / 0.457 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 15 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.6 x 1 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 15 |
| Вес | 14.76 г |
| Ширина | 90.8 mm / 3.575 inch |
Серия: 722 (100 из 306)
- 722-237 722-237/005-000 722-237/005-000/039-000 722-237/031-000 722-237/039-000 722-237/047-000 722-238 722-238/005-000 722-238/005-000/039-000 722-238/031-000 722-238/039-000 722-238/047-000 722-239 722-239/005-000 722-239/005-000/039-000 722-239/031-000 722-239/039-000 722-239/047-000 722-240 722-240/005-000 722-240/005-000/039-000 722-240/031-000 722-240/039-000 722-240/047-000 722-241 722-241/005-000 722-241/005-000/039-000 722-241/031-000 722-241/039-000 722-241/047-000 722-242 722-242/005-000 722-242/005-000/039-000 722-242/031-000 722-242/039-000 722-242/047-000 722-243 722-243/005-000 722-243/031-000 722-243/039-000 722-243/047-000 722-244 722-244/005-000 722-244/005-000/039-000 722-244/031-000 722-244/039-000 722-244/047-000 722-245 722-245/005-000 722-245/031-000 722-245/039-000 722-245/047-000 722-246 722-246/005-000 722-246/005-000/039-000 722-246/031-000 722-246/039-000 722-246/047-000 722-250 722-250/005-000 722-250/005-000/039-000 722-250/031-000 722-250/039-000 722-250/047-000 722-732 722-732/031-000 722-732/039-000 722-732/047-000 722-733 722-733/031-000 722-733/039-000 722-733/047-000 722-734 722-734/031-000 722-734/039-000 722-734/047-000 722-735 722-735/031-000 722-735/039-000 722-735/047-000 722-736 722-736/031-000 722-736/039-000 722-736/047-000 722-737 722-737/031-000 722-737/039-000 722-737/047-000 722-738 722-738/031-000 722-738/039-000 722-738/047-000 722-739 722-739/031-000 722-739/039-000 722-739/047-000 722-740 722-740/031-000 722-740/039-000 722-740/047-000
722245/039000, 722 245/039 000
