Datasheet Wago 723-607/018-000 — Даташит
1-проводная вилка; 100% защита от неправильного подсоединения; Монтажные ножки; 2,5 мм²; Шаг контактов 2,5 мм; 7-пол.
1-CONDUCTOR MALE CONNECTOR; 100% | |||
| 723-607/018-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 27.5 mm / 1.083 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.247 MJ |
| GTIN | 4044918265850 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 18.8 mm / 0.74 inch |
| Height from the surface | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 7 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Type of mounting | Panel mounting |
| Вес | 12.58 г |
| Ширина | 53.2 mm / 2.094 inch |
Серия: 723 (61)
- 723-602 723-602/000-040 723-602/018-000 723-602/019-000 723-602/032-000 723-602/032-040 723-602/114-000 723-603 723-603/000-042 723-603/018-000 723-603/018-042 723-603/019-000 723-603/019-042 723-603/032-000 723-603/114-000 723-603/114-042 723-604 723-604/000-042 723-604/018-000 723-604/018-042 723-604/019-000 723-604/019-042 723-604/114-000 723-604/114-042 723-605 723-605/000-042 723-605/018-000 723-605/018-042 723-605/019-000 723-605/019-042 723-605/114-000 723-605/114-042 723-606 723-606/018-000 723-606/019-000 723-606/114-000 723-607 723-607/018-000 723-607/019-000 723-607/114-000 723-608 723-608/018-000 723-608/019-000 723-608/019-000/035-000 723-608/114-000 723-609 723-609/018-000 723-609/019-000 723-609/114-000 723-610 723-610/018-000 723-610/019-000 723-610/114-000 723-611 723-611/018-000 723-611/019-000 723-611/114-000 723-612 723-612/018-000 723-612/019-000 723-612/114-000
723607/018000, 723 607/018 000
