Datasheet Wago 731-520/008-000 — Даташит
1-проводниковая розетка; угловые; Монтажные ножки; 2,5 мм²; Шаг контактов 5 мм; 20-пол.
PE7315-20 Pasternack | от 90 767 ₽ | ||
B731520 | по запросу |
Цвет | gray |
Conductor entry direction to mating direction | 90 ° |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 23 mm / 0.906 inch |
Design | angled, mountable |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.547 MJ |
GTIN | 4044918575676 |
Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
Height | 17.6 mm / 0.693 inch |
Height from the surface | 13.1 mm / 0.516 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Snap-in mounting foot |
Number of Poles | 20 |
Number of levels | 1 |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 7 … 8 mm / 0.28 … 0.31 Inch |
Total number of connection points | 20 |
Total number of potentials | 20 |
Type of mounting | Panel mounting |
Вес | 28.54 г |
Ширина | 101.5 mm / 3.996 inch |
Серия: 731 (100 из 184)
- 731-140/048-000 731-141/048-000 731-142/048-000 731-162 731-163 731-164 731-165 731-166/048-000 731-167/048-000 731-168/048-000 731-169/048-000 731-170/048-000 731-171/048-000 731-172/048-000 731-502/008-000 731-502/031-000 731-503/008-000 731-503/031-000 731-504/008-000 731-504/031-000 731-505/008-000 731-505/031-000 731-506/008-000 731-506/031-000 731-507/008-000 731-507/031-000 731-508/008-000 731-508/031-000 731-509/008-000 731-509/031-000 731-510/008-000 731-510/031-000 731-511/008-000 731-511/031-000 731-512/008-000 731-512/031-000 731-513/008-000 731-513/031-000 731-514/008-000 731-514/031-000 731-515/008-000 731-515/031-000 731-516/008-000 731-516/031-000 731-517/008-000 731-517/031-000 731-518/008-000 731-518/031-000 731-519/008-000 731-519/031-000 731-520/008-000 731-520/031-000 731-532/008-000 731-532/031-000 731-533/008-000 731-533/031-000 731-534/008-000 731-534/031-000 731-535/008-000 731-535/031-000 731-536/008-000 731-536/031-000 731-537/008-000 731-537/031-000 731-538/008-000 731-538/031-000 731-539/008-000 731-539/031-000 731-540/008-000 731-540/031-000 731-541/008-000 731-541/031-000 731-542/008-000 731-542/031-000 731-543/008-000 731-543/031-000 731-546/008-000 731-546/031-000 731-602 731-602/018-000 731-602/019-000 731-602/114-000 731-603 731-603/018-000 731-603/019-000 731-603/114-000 731-604 731-604/018-000 731-604/019-000 731-604/114-000 731-605 731-605/018-000 731-605/019-000 731-605/114-000 731-606 731-606/018-000 731-606/019-000 731-606/114-000 731-607 731-607/018-000
731520/008000, 731 520/008 000
