Datasheet Wago 731-540/008-000 — Даташит
1-проводниковая розетка; угловые; Монтажные ножки; 2,5 мм²; Шаг контактов 7,5 мм; 10-пол.
1-CONDUCTOR FEMALE PLUG; ANGLED; | |||
| 731-540/008-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry direction to mating direction | 90 ° |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | PL |
| Габариты: глубина | 23 mm / 0.906 inch |
| Design | angled, mountable |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.358 MJ |
| GTIN | 4044918575867 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 17.6 mm / 0.693 inch |
| Height from the surface | 13.1 mm / 0.516 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 10 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 7 … 8 mm / 0.28 … 0.31 Inch |
| Total number of connection points | 10 |
| Total number of potentials | 10 |
| Type of mounting | Panel mounting |
| Вес | 17.09 г |
| Ширина | 74 mm / 2.913 inch |
Серия: 731 (100 из 184)
- 731-504/008-000 731-504/031-000 731-505/008-000 731-505/031-000 731-506/008-000 731-506/031-000 731-507/008-000 731-507/031-000 731-508/008-000 731-508/031-000 731-509/008-000 731-509/031-000 731-510/008-000 731-510/031-000 731-511/008-000 731-511/031-000 731-512/008-000 731-512/031-000 731-513/008-000 731-513/031-000 731-514/008-000 731-514/031-000 731-515/008-000 731-515/031-000 731-516/008-000 731-516/031-000 731-517/008-000 731-517/031-000 731-518/008-000 731-518/031-000 731-519/008-000 731-519/031-000 731-520/008-000 731-520/031-000 731-532/008-000 731-532/031-000 731-533/008-000 731-533/031-000 731-534/008-000 731-534/031-000 731-535/008-000 731-535/031-000 731-536/008-000 731-536/031-000 731-537/008-000 731-537/031-000 731-538/008-000 731-538/031-000 731-539/008-000 731-539/031-000 731-540/008-000 731-540/031-000 731-541/008-000 731-541/031-000 731-542/008-000 731-542/031-000 731-543/008-000 731-543/031-000 731-546/008-000 731-546/031-000 731-602 731-602/018-000 731-602/019-000 731-602/114-000 731-603 731-603/018-000 731-603/019-000 731-603/114-000 731-604 731-604/018-000 731-604/019-000 731-604/114-000 731-605 731-605/018-000 731-605/019-000 731-605/114-000 731-606 731-606/018-000 731-606/019-000 731-606/114-000 731-607 731-607/018-000 731-607/019-000 731-607/114-000 731-608 731-608/018-000 731-608/019-000 731-608/114-000 731-609 731-609/018-000 731-609/019-000 731-609/114-000 731-610 731-610/018-000 731-610/019-000 731-610/114-000 731-611 731-611/018-000 731-611/019-000 731-611/114-000
731540/008000, 731 540/008 000
