Datasheet Wago 731-546/031-000 — Даташит
1-проводниковая розетка; угловые; зажимное кольцо; 2,5 мм²; Шаг контактов 7,5 мм; 16-пол.
731-546/008-000 Wago | по запросу | ||
B731546 | по запросу |
Цвет | gray |
Conductor entry direction to mating direction | 90 ° |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 23 mm / 0.906 inch |
Design | angled, mountable |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.579 MJ |
GTIN | 4044918575805 |
Height | 13.1 mm / 0.516 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 16 |
Number of levels | 1 |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 7 … 8 mm / 0.28 … 0.31 Inch |
Total number of connection points | 16 |
Total number of potentials | 16 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 27.48 г |
Ширина | 132.3 mm / 5.209 inch |
Серия: 731 (100 из 184)
- 731-508/031-000 731-509/008-000 731-509/031-000 731-510/008-000 731-510/031-000 731-511/008-000 731-511/031-000 731-512/008-000 731-512/031-000 731-513/008-000 731-513/031-000 731-514/008-000 731-514/031-000 731-515/008-000 731-515/031-000 731-516/008-000 731-516/031-000 731-517/008-000 731-517/031-000 731-518/008-000 731-518/031-000 731-519/008-000 731-519/031-000 731-520/008-000 731-520/031-000 731-532/008-000 731-532/031-000 731-533/008-000 731-533/031-000 731-534/008-000 731-534/031-000 731-535/008-000 731-535/031-000 731-536/008-000 731-536/031-000 731-537/008-000 731-537/031-000 731-538/008-000 731-538/031-000 731-539/008-000 731-539/031-000 731-540/008-000 731-540/031-000 731-541/008-000 731-541/031-000 731-542/008-000 731-542/031-000 731-543/008-000 731-543/031-000 731-546/008-000 731-546/031-000 731-602 731-602/018-000 731-602/019-000 731-602/114-000 731-603 731-603/018-000 731-603/019-000 731-603/114-000 731-604 731-604/018-000 731-604/019-000 731-604/114-000 731-605 731-605/018-000 731-605/019-000 731-605/114-000 731-606 731-606/018-000 731-606/019-000 731-606/114-000 731-607 731-607/018-000 731-607/019-000 731-607/114-000 731-608 731-608/018-000 731-608/019-000 731-608/114-000 731-609 731-609/018-000 731-609/019-000 731-609/114-000 731-610 731-610/018-000 731-610/019-000 731-610/114-000 731-611 731-611/018-000 731-611/019-000 731-611/114-000 731-612 731-612/018-000 731-612/019-000 731-612/114-000 731-613 731-613/018-000 731-613/019-000 731-613/114-000 731-616
731546/031000, 731 546/031 000
