Datasheet Wago 731-607/114-000 — Даташит
1-проводная вилка; Защелкивающийся фланец; 2,5 мм²; Шаг контактов 7,5 мм; 7-пол.
| 1-CONDUCTOR MALE CONNECTOR; SNAP | |||
| 731-607/114-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 27.5 mm / 1.083 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.303 MJ |
| GTIN | 4050821282310 |
| Gehäuseblechstärke | 0.5 … 2.5 mm / 0.02 … 0.098 inch |
| Height | 17.5 mm / 0.689 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Snap-in |
| Number of Poles | 7 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Type of mounting | Feed-through mounting |
| Вес | 14.45 г |
| Ширина | 71 mm / 2.795 inch |
Серия: 731 (100 из 184)
- 731-520/031-000 731-532/008-000 731-532/031-000 731-533/008-000 731-533/031-000 731-534/008-000 731-534/031-000 731-535/008-000 731-535/031-000 731-536/008-000 731-536/031-000 731-537/008-000 731-537/031-000 731-538/008-000 731-538/031-000 731-539/008-000 731-539/031-000 731-540/008-000 731-540/031-000 731-541/008-000 731-541/031-000 731-542/008-000 731-542/031-000 731-543/008-000 731-543/031-000 731-546/008-000 731-546/031-000 731-602 731-602/018-000 731-602/019-000 731-602/114-000 731-603 731-603/018-000 731-603/019-000 731-603/114-000 731-604 731-604/018-000 731-604/019-000 731-604/114-000 731-605 731-605/018-000 731-605/019-000 731-605/114-000 731-606 731-606/018-000 731-606/019-000 731-606/114-000 731-607 731-607/018-000 731-607/019-000 731-607/114-000 731-608 731-608/018-000 731-608/019-000 731-608/114-000 731-609 731-609/018-000 731-609/019-000 731-609/114-000 731-610 731-610/018-000 731-610/019-000 731-610/114-000 731-611 731-611/018-000 731-611/019-000 731-611/114-000 731-612 731-612/018-000 731-612/019-000 731-612/114-000 731-613 731-613/018-000 731-613/019-000 731-613/114-000 731-616 731-616/018-000 731-616/019-000 731-616/114-000 731-632 731-632/000-044 731-632/018-000 731-632/019-000 731-632/114-000 731-633 731-633/018-000 731-633/019-000 731-633/114-000 731-634 731-634/018-000 731-634/019-000 731-634/114-000 731-635 731-635/018-000 731-635/018-000/033-000 731-635/019-000 731-635/114-000 731-636 731-636/018-000 731-636/019-000
731607/114000, 731 607/114 000
