Datasheet Wago 732-103/026-000 — Даташит
1-проводниковая розетка; угловые; 2,5 мм²; Шаг контактов 7,5 мм; 3-пол.
1-CONDUCTOR FEMALE PLUG; ANGLED; | |||
| 732-103/026-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Conductor entry direction to mating direction | 270 ° |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 22.75 mm / 0.896 inch |
| Design | angled |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.122 MJ |
| GTIN | 4044918391610 |
| Height | 23.9 mm / 0.941 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 14 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 6.895 г |
| Ширина | 22.4 mm / 0.882 inch |
Серия: 732 (24)
- 732-102/026-000 732-103/026-000 732-104/026-000 732-105/026-000 732-106/026-000 732-107/026-000 732-108/026-000 732-109/026-000 732-110/026-000 732-111/026-000 732-112/026-000 732-116/026-000 732-116/026-000/035-000 732-122/026-000 732-123/026-000 732-124/026-000 732-125/026-000 732-126/026-000 732-127/026-000 732-128/026-000 732-129/026-000 732-130/026-000 732-131/026-000 732-132/026-000
732103/026000, 732 103/026 000
