Datasheet Wago 733-364/105-604/997-406 — Даташит
Вилка под пайку THR; 0.8 x 0.8 mm solder pin; угловые; 100% защита от неправильного подсоединения; упаковка в ленте на бобине; Шаг контактов 2,5 мм; 4-пол.
THR MALE HEADER; 0.8 X 0.8 MM SO | |||
| 733-364/105-604/997-406 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 8.9 mm / 0.35 inch |
| Fire load | 0.018 MJ |
| GTIN | 4045454815073 |
| Height | 10.2 mm / 0.402 inch |
| Height from the surface | 7.8 mm / 0.307 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 4 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Packaging type | bag |
| Pin spacing | 2.5 mm (0.098 inch) |
| Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
| Rated current | 6 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Reel diameter of tape-and-reel packaging | 330 мм |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 0.8 x 0.8 mm |
| Solder pin length | 2.4 мм |
| Tape width | 44 мм |
| Total number of potentials | 4 |
| Вес | 0.71 г |
| Ширина | 12.5 mm / 0.492 inch |
Серия: 733 (100 из 104)
- 733-103/037-000 733-104 733-104/037-000 733-105 733-105/010-000 733-105/037-000 733-106 733-106/037-000 733-107 733-107/037-000 733-108 733-108/037-000 733-109 733-109/037-000 733-110 733-110/037-000 733-112 733-112/037-000 733-202 733-202/032-000 733-203 733-203/032-000 733-204 733-204/032-000 733-205 733-205/033-000 733-206 733-206/033-000 733-207 733-207/033-000 733-208 733-208/033-000 733-209 733-209/033-000 733-210 733-210/034-000 733-212 733-212/034-000 733-330 733-331 733-332 733-332/105-604 733-332/105-604/997-446 733-333 733-333/105-604 733-333/105-604/997-446 733-334 733-334/105-604 733-334/105-604/997-446 733-335 733-335/105-604 733-335/105-604/997-446 733-336 733-336/105-604 733-336/105-604/997-446 733-337 733-337/105-604 733-337/105-604/997-446 733-338 733-338/105-604 733-338/105-604/997-446 733-339 733-339/105-604 733-339/105-604/997-446 733-340 733-340/105-604 733-340/105-604/997-446 733-342 733-342/105-604 733-342/105-604/997-446 733-362 733-362/105-604 733-362/105-604/997-406 733-363 733-363/105-604 733-363/105-604/997-406 733-364 733-364/105-604 733-364/105-604/997-406 733-365 733-365/105-604 733-365/105-604/997-406 733-366 733-366/105-604 733-366/105-604/997-406 733-367 733-367/105-604 733-367/105-604/997-406 733-368 733-368/105-604 733-368/105-604/997-406 733-369 733-369/105-604 733-369/105-604/997-406 733-370 733-370/105-604 733-370/105-604/997-406 733-372 733-372/105-604 733-372/105-604/997-406
733364/105604/997406, 733 364/105 604/997 406
