Datasheet Wago 734-107/033-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Пластина разгрузки натяжения; 1,5; Шаг контактов 3,5 мм; 7-пол.
| 1-CONDUCTOR FEMALE PLUG; 100% PR | |||
| 734-107/033-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.6 mm / 0.732 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.093 MJ |
| GTIN | 4044918495004 |
| Height | 13.4 mm / 0.528 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 7 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Вес | 5.68 г |
| Ширина | 26.7 mm / 1.051 inch |
Серия: 734 (100 из 708)
- 734-102 734-102/008-000 734-102/037-000 734-102/037-000/032-000 734-102/107-000 734-103 734-103/008-000 734-103/037-000 734-103/037-000/032-000 734-103/107-000 734-104 734-104/008-000 734-104/037-000 734-104/037-000/033-000 734-104/107-000 734-105 734-105/008-000 734-105/037-000 734-105/037-000/033-000 734-105/107-000 734-106 734-106/008-000 734-106/037-000 734-106/037-000/033-000 734-106/107-000 734-107 734-107/008-000 734-107/033-000 734-107/037-000 734-107/037-000/033-000 734-107/107-000 734-108 734-108/008-000 734-108/037-000 734-108/037-000/033-000 734-108/107-000 734-109 734-109/008-000 734-109/037-000 734-109/037-000/034-000 734-109/107-000 734-110 734-110/000-005 734-110/000-006 734-110/008-000 734-110/037-000 734-110/107-000 734-111 734-111/008-000 734-111/037-000 734-111/037-000/034-000 734-111/107-000 734-112 734-112/008-000 734-112/037-000 734-112/107-000 734-113 734-113/008-000 734-113/037-000 734-113/037-000/035-000 734-113/107-000 734-114 734-114/008-000 734-114/037-000 734-114/037-000/035-000 734-114/107-000 734-116 734-116/008-000 734-116/037-000 734-116/037-000/035-000 734-116/107-000 734-118 734-118/008-000 734-118/037-000 734-118/037-000/036-000 734-118/107-000 734-120 734-120/008-000 734-120/037-000 734-120/037-000/036-000 734-120/107-000 734-124 734-124/008-000 734-124/037-000 734-124/037-000/036-000 734-124/107-000 734-126 734-127 734-128 734-129 734-130 734-132 734-132/046-000 734-132/105-604 734-132/105-604/997-405 734-132/108-000 734-133 734-133/010-000 734-133/046-000 734-133/105-604
734107/033000, 734 107/033 000
