Datasheet Wago 734-143 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 3,5 мм; 13-пол.
![]() 10 предложений от 3 поставщиков THT MALE HEADER; 1.0 X 1.0 MM SO | |||
734-143 Wago | от 732 ₽ | ||
734-143 | от 737 ₽ | ||
734-143/010-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 8.5 mm / 0.335 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.047 MJ |
GTIN | 4044918847735 |
Height | 14.8 mm / 0.583 inch |
Height from the surface | 10.3 mm / 0.406 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | Yes |
Number of Poles | 13 |
Number of levels | 1 |
PCB contact | THT |
Rated current | 10 A |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 4.5 мм |
Total number of potentials | 13 |
Вес | 2.88 г |
Ширина | 47.9 mm / 1.886 inch |
Серия: 734 (100 из 708)
- 734-134/046-000 734-134/105-604 734-134/105-604/997-405 734-134/108-000 734-135 734-135/010-000 734-135/046-000 734-135/105-604 734-135/105-604/997-405 734-135/108-000 734-136 734-136/010-000 734-136/046-000 734-136/105-604 734-136/105-604/997-407 734-136/108-000 734-137 734-137/010-000 734-137/046-000 734-137/105-604 734-137/105-604/997-407 734-137/108-000 734-138 734-138/010-000 734-138/046-000 734-138/105-604 734-138/105-604/997-407 734-138/108-000 734-139 734-139/010-000 734-139/046-000 734-139/105-604 734-139/105-604/997-407 734-139/108-000 734-140 734-140/046-000 734-140/105-604 734-140/105-604/997-407 734-140/108-000 734-141 734-141/046-000 734-141/105-604 734-141/105-604/997-407 734-141/108-000 734-142 734-142/010-000 734-142/046-000 734-142/105-604 734-142/105-604/997-407 734-142/108-000 734-143 734-143/010-000 734-143/108-000 734-144 734-144/010-000 734-144/105-604 734-144/105-604/997-408 734-144/108-000 734-146 734-146/010-000 734-146/046-000 734-146/105-604/997-408 734-146/108-000 734-148 734-148/108-000 734-150 734-150/010-000 734-150/046-000 734-150/108-000 734-154 734-154/046-000 734-154/108-000 734-159 734-162 734-162/105-604 734-162/105-604/997-405 734-162/108-000 734-163 734-163/105-604 734-163/105-604/997-405 734-163/108-000 734-164 734-164/105-604 734-164/105-604/997-405 734-164/108-000 734-165 734-165/105-604 734-165/105-604/997-405 734-165/108-000 734-166 734-166/105-604 734-166/105-604/997-407 734-166/108-000 734-167 734-167/105-604 734-167/105-604/997-407 734-167/108-000 734-168 734-168/105-604 734-168/105-604/997-407
