Datasheet Wago 734-154/046-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 3,5 мм; 24-пол.
| 734-154/046-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 8.5 mm / 0.335 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fire load | 0.087 MJ |
| GTIN | 4050821361992 |
| Height | 14.1 mm / 0.555 inch |
| Height from the surface | 8.5 mm / 0.335 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 24 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 4.5 мм |
| Total number of potentials | 24 |
| Вес | 5.348 г |
| Ширина | 86.4 mm / 3.402 inch |
Серия: 734 (100 из 708)
- 734-137/105-604/997-407 734-137/108-000 734-138 734-138/010-000 734-138/046-000 734-138/105-604 734-138/105-604/997-407 734-138/108-000 734-139 734-139/010-000 734-139/046-000 734-139/105-604 734-139/105-604/997-407 734-139/108-000 734-140 734-140/046-000 734-140/105-604 734-140/105-604/997-407 734-140/108-000 734-141 734-141/046-000 734-141/105-604 734-141/105-604/997-407 734-141/108-000 734-142 734-142/010-000 734-142/046-000 734-142/105-604 734-142/105-604/997-407 734-142/108-000 734-143 734-143/010-000 734-143/108-000 734-144 734-144/010-000 734-144/105-604 734-144/105-604/997-408 734-144/108-000 734-146 734-146/010-000 734-146/046-000 734-146/105-604/997-408 734-146/108-000 734-148 734-148/108-000 734-150 734-150/010-000 734-150/046-000 734-150/108-000 734-154 734-154/046-000 734-154/108-000 734-159 734-162 734-162/105-604 734-162/105-604/997-405 734-162/108-000 734-163 734-163/105-604 734-163/105-604/997-405 734-163/108-000 734-164 734-164/105-604 734-164/105-604/997-405 734-164/108-000 734-165 734-165/105-604 734-165/105-604/997-405 734-165/108-000 734-166 734-166/105-604 734-166/105-604/997-407 734-166/108-000 734-167 734-167/105-604 734-167/105-604/997-407 734-167/108-000 734-168 734-168/105-604 734-168/105-604/997-407 734-168/108-000 734-169 734-169/105-604 734-169/105-604/997-407 734-169/108-000 734-170 734-170/105-604 734-170/105-604/997-407 734-170/108-000 734-171 734-171/105-604 734-171/105-604/997-407 734-171/108-000 734-172 734-172/105-604 734-172/105-604/997-407 734-172/108-000 734-173 734-173/108-000 734-174
734154/046000, 734 154/046 000
