Datasheet Wago 734-164/108-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; угловые; 100% защита от неправильного подсоединения; Резьбовой фланец; Шаг контактов 3,5 мм; 4-пол.
![]() 11 предложений от 4 поставщиков HEADER MALE R/A THREADED 4POS | |||
734-164/108-000 Wago | от 531 ₽ | ||
734-164/108-000 | от 535 ₽ | ||
734-164/108-000 Wago | 1 907 ₽ | ||
734-164/108-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 10.3 mm / 0.406 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.027 MJ |
GTIN | 4045454683054 |
Height | 12.3 mm / 0.484 inch |
Height from the surface | 8.5 mm / 0.335 inch |
Locking of plug-in connection | Threaded flange |
Material group | I |
Mismating protection | Yes |
Number of Poles | 4 |
Number of levels | 1 |
PCB contact | THT |
Rated current | 10 A |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 3.8 мм |
Total number of potentials | 4 |
Вес | 1.778 г |
Ширина | 23.5 mm / 0.925 inch |
Серия: 734 (100 из 708)
- 734-140 734-140/046-000 734-140/105-604 734-140/105-604/997-407 734-140/108-000 734-141 734-141/046-000 734-141/105-604 734-141/105-604/997-407 734-141/108-000 734-142 734-142/010-000 734-142/046-000 734-142/105-604 734-142/105-604/997-407 734-142/108-000 734-143 734-143/010-000 734-143/108-000 734-144 734-144/010-000 734-144/105-604 734-144/105-604/997-408 734-144/108-000 734-146 734-146/010-000 734-146/046-000 734-146/105-604/997-408 734-146/108-000 734-148 734-148/108-000 734-150 734-150/010-000 734-150/046-000 734-150/108-000 734-154 734-154/046-000 734-154/108-000 734-159 734-162 734-162/105-604 734-162/105-604/997-405 734-162/108-000 734-163 734-163/105-604 734-163/105-604/997-405 734-163/108-000 734-164 734-164/105-604 734-164/105-604/997-405 734-164/108-000 734-165 734-165/105-604 734-165/105-604/997-405 734-165/108-000 734-166 734-166/105-604 734-166/105-604/997-407 734-166/108-000 734-167 734-167/105-604 734-167/105-604/997-407 734-167/108-000 734-168 734-168/105-604 734-168/105-604/997-407 734-168/108-000 734-169 734-169/105-604 734-169/105-604/997-407 734-169/108-000 734-170 734-170/105-604 734-170/105-604/997-407 734-170/108-000 734-171 734-171/105-604 734-171/105-604/997-407 734-171/108-000 734-172 734-172/105-604 734-172/105-604/997-407 734-172/108-000 734-173 734-173/108-000 734-174 734-174/105-604 734-174/105-604/997-408 734-174/108-000 734-176 734-176/105-604 734-176/105-604/997-408 734-176/108-000 734-178 734-178/108-000 734-180 734-180/108-000 734-184 734-184/108-000 734-202
734164/108000, 734 164/108 000
