Datasheet Wago 734-176/108-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; угловые; 100% защита от неправильного подсоединения; Резьбовой фланец; Шаг контактов 3,5 мм; 16-пол.
![]() 11 предложений от 4 поставщиков HEADER MALE R/A THREADED 16POS | |||
734-176/108-000 Wago | от 1 137 ₽ | ||
734-176/108-000 | от 1 146 ₽ | ||
734-176/108-000 Wago | 1 833 ₽ | ||
734-176/108-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 10.3 mm / 0.406 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.068 MJ |
GTIN | 4045454683139 |
Height | 12.3 mm / 0.484 inch |
Height from the surface | 8.5 mm / 0.335 inch |
Locking of plug-in connection | Threaded flange |
Material group | I |
Mismating protection | Yes |
Number of Poles | 16 |
Number of levels | 1 |
PCB contact | THT |
Rated current | 10 A |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1 x 1 mm |
Solder pin length | 3.8 мм |
Total number of potentials | 16 |
Вес | 4.722 г |
Ширина | 65.5 mm / 2.579 inch |
Серия: 734 (100 из 708)
- 734-162/108-000 734-163 734-163/105-604 734-163/105-604/997-405 734-163/108-000 734-164 734-164/105-604 734-164/105-604/997-405 734-164/108-000 734-165 734-165/105-604 734-165/105-604/997-405 734-165/108-000 734-166 734-166/105-604 734-166/105-604/997-407 734-166/108-000 734-167 734-167/105-604 734-167/105-604/997-407 734-167/108-000 734-168 734-168/105-604 734-168/105-604/997-407 734-168/108-000 734-169 734-169/105-604 734-169/105-604/997-407 734-169/108-000 734-170 734-170/105-604 734-170/105-604/997-407 734-170/108-000 734-171 734-171/105-604 734-171/105-604/997-407 734-171/108-000 734-172 734-172/105-604 734-172/105-604/997-407 734-172/108-000 734-173 734-173/108-000 734-174 734-174/105-604 734-174/105-604/997-408 734-174/108-000 734-176 734-176/105-604 734-176/105-604/997-408 734-176/108-000 734-178 734-178/108-000 734-180 734-180/108-000 734-184 734-184/108-000 734-202 734-202/008-000 734-202/037-000 734-203 734-203/008-000 734-203/037-000 734-204 734-204/008-000 734-204/037-000 734-205 734-205/008-000 734-205/037-000 734-206 734-206/008-000 734-206/037-000 734-208 734-208/008-000 734-208/037-000 734-209 734-209/008-000 734-209/037-000 734-210 734-210/008-000 734-210/037-000 734-212 734-212/008-000 734-212/037-000 734-214 734-214/008-000 734-214/037-000 734-215 734-215/008-000 734-215/037-000 734-216 734-216/008-000 734-216/037-000 734-218 734-218/008-000 734-218/037-000 734-219 734-219/008-000 734-219/037-000 734-220
734176/108000, 734 176/108 000
