Datasheet Wago 734-203/008-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Монтажные ножки; 1,5; Шаг контактов 3,81 мм; 3-пол.
Купить 734-203 на РадиоЛоцман.Цены — от 47 до 680 ₽29 предложений от 11 поставщиков Съемная клеммная колодка, 3.81 мм, 3 вывод(-ов), 28AWG до 14AWG, 1.5 мм², Зажим, 10 А | |||
| 734-203 Wago | 545 ₽ | ||
| 734-203 | от 561 ₽ | ||
| 734-203/037-000 | по запросу | ||
| 734-203 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 18.6 mm / 0.732 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.05 MJ |
| GTIN | 4045454942397 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 18.9 mm / 0.744 inch |
| Height from the surface | 13.4 mm / 0.528 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.81 mm (0.15 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Type of mounting | Panel mounting |
| Вес | 2.684 г |
| Ширина | 13.63 mm / 0.537 inch |
Серия: 734 (100 из 708)
- 734-165/105-604/997-405 734-165/108-000 734-166 734-166/105-604 734-166/105-604/997-407 734-166/108-000 734-167 734-167/105-604 734-167/105-604/997-407 734-167/108-000 734-168 734-168/105-604 734-168/105-604/997-407 734-168/108-000 734-169 734-169/105-604 734-169/105-604/997-407 734-169/108-000 734-170 734-170/105-604 734-170/105-604/997-407 734-170/108-000 734-171 734-171/105-604 734-171/105-604/997-407 734-171/108-000 734-172 734-172/105-604 734-172/105-604/997-407 734-172/108-000 734-173 734-173/108-000 734-174 734-174/105-604 734-174/105-604/997-408 734-174/108-000 734-176 734-176/105-604 734-176/105-604/997-408 734-176/108-000 734-178 734-178/108-000 734-180 734-180/108-000 734-184 734-184/108-000 734-202 734-202/008-000 734-202/037-000 734-203 734-203/008-000 734-203/037-000 734-204 734-204/008-000 734-204/037-000 734-205 734-205/008-000 734-205/037-000 734-206 734-206/008-000 734-206/037-000 734-208 734-208/008-000 734-208/037-000 734-209 734-209/008-000 734-209/037-000 734-210 734-210/008-000 734-210/037-000 734-212 734-212/008-000 734-212/037-000 734-214 734-214/008-000 734-214/037-000 734-215 734-215/008-000 734-215/037-000 734-216 734-216/008-000 734-216/037-000 734-218 734-218/008-000 734-218/037-000 734-219 734-219/008-000 734-219/037-000 734-220 734-220/008-000 734-220/037-000 734-226 734-227 734-228 734-229 734-230 734-232 734-232/046-000 734-232/105-604 734-232/105-604/997-405
734203/008000, 734 203/008 000
