Datasheet Wago 734-274 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; угловые; 100% защита от неправильного подсоединения; Шаг контактов 3,81 мм; 14-пол.
| THT MALE HEADER; 1.0 X 1.0 MM SO | |||
| 734-274 Wago | по запросу | ||
| Цвет | orange |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 10.3 mm / 0.406 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fire load | 0.057 MJ |
| GTIN | 4044918872683 |
| Height | 12.3 mm / 0.484 inch |
| Height from the surface | 8.5 mm / 0.335 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 14 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.81 mm (0.15 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 3.8 мм |
| Total number of potentials | 14 |
| Вес | 3.748 г |
| Ширина | 55.43 mm / 2.182 inch |
Серия: 734 (100 из 708)
- 734-238/105-604/997-407 734-239 734-239/046-000 734-239/105-604 734-240 734-240/046-000 734-240/105-604 734-240/105-604/997-407 734-242 734-242/046-000 734-242/105-604 734-242/105-604/997-408 734-244 734-244/046-000 734-245 734-246 734-246/046-000 734-248 734-248/046-000 734-249 734-249/046-000 734-250 734-250/046-000 734-262 734-262/105-604 734-262/105-604/997-405 734-263 734-263/105-604 734-263/105-604/997-405 734-264 734-264/105-604 734-264/105-604/997-405 734-265 734-265/105-604 734-265/105-604/997-407 734-266 734-266/105-604 734-266/105-604/997-407 734-268 734-268/105-604 734-268/105-604/997-407 734-269 734-269/105-604 734-269/105-604/997-407 734-270 734-270/105-604 734-270/105-604/997-407 734-272 734-272/105-604 734-272/105-604/997-408 734-274 734-275 734-276 734-278 734-279 734-280 734-302 734-302/018-000 734-302/019-000 734-302/109-000 734-303 734-303/018-000 734-303/019-000 734-303/109-000 734-304 734-304/018-000 734-304/019-000 734-304/109-000 734-305 734-305/018-000 734-305/019-000 734-305/033-000 734-305/109-000 734-306 734-306/018-000 734-306/019-000 734-306/109-000 734-307 734-307/018-000 734-307/019-000 734-307/033-000 734-307/109-000 734-308 734-308/018-000 734-308/019-000 734-308/109-000 734-309 734-309/018-000 734-309/019-000 734-309/109-000 734-310 734-310/018-000 734-310/019-000 734-310/109-000 734-311 734-311/018-000 734-311/019-000 734-311/109-000 734-312 734-312/018-000
