Datasheet Wago 734-303/109-000 — Даташит
1-проводная вилка; 100% защита от неправильного подсоединения; Резьбовой фланец; 1,5; Шаг контактов 3,5 мм; 3-пол.
| 1-CONDUCTOR MALE CONNECTOR; 100% | |||
| 734-303/109-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 22.3 mm / 0.878 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.065 MJ |
| GTIN | 4045454695040 |
| Height | 13.4 mm / 0.528 inch |
| Limit temperature range | -60 … +100 °C |
| Locking of plug-in connection | Threaded flange |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 3 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 3 |
| Total number of potentials | 3 |
| Вес | 3.319 г |
| Ширина | 20 mm / 0.787 inch |
Серия: 734 (100 из 708)
- 734-244/046-000 734-245 734-246 734-246/046-000 734-248 734-248/046-000 734-249 734-249/046-000 734-250 734-250/046-000 734-262 734-262/105-604 734-262/105-604/997-405 734-263 734-263/105-604 734-263/105-604/997-405 734-264 734-264/105-604 734-264/105-604/997-405 734-265 734-265/105-604 734-265/105-604/997-407 734-266 734-266/105-604 734-266/105-604/997-407 734-268 734-268/105-604 734-268/105-604/997-407 734-269 734-269/105-604 734-269/105-604/997-407 734-270 734-270/105-604 734-270/105-604/997-407 734-272 734-272/105-604 734-272/105-604/997-408 734-274 734-275 734-276 734-278 734-279 734-280 734-302 734-302/018-000 734-302/019-000 734-302/109-000 734-303 734-303/018-000 734-303/019-000 734-303/109-000 734-304 734-304/018-000 734-304/019-000 734-304/109-000 734-305 734-305/018-000 734-305/019-000 734-305/033-000 734-305/109-000 734-306 734-306/018-000 734-306/019-000 734-306/109-000 734-307 734-307/018-000 734-307/019-000 734-307/033-000 734-307/109-000 734-308 734-308/018-000 734-308/019-000 734-308/109-000 734-309 734-309/018-000 734-309/019-000 734-309/109-000 734-310 734-310/018-000 734-310/019-000 734-310/109-000 734-311 734-311/018-000 734-311/019-000 734-311/109-000 734-312 734-312/018-000 734-312/019-000 734-312/109-000 734-313 734-313/018-000 734-313/019-000 734-313/109-000 734-314 734-314/018-000 734-314/019-000 734-314/109-000 734-316 734-316/018-000 734-316/019-000
734303/109000, 734 303/109 000
