Datasheet Wago 734-314/019-000 — Даташит
1-проводная вилка; 100% защита от неправильного подсоединения; зажимное кольцо; 1,5; Шаг контактов 3,5 мм; 14-пол.
| 1-CONDUCTOR MALE CONNECTOR100% PROTECTED AGAINST MISMATING, LIGHT GRAY | |||
| 734-314/019-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | PL |
| Габариты: глубина | 22.3 mm / 0.878 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.247 MJ |
| GTIN | 4055143268998 |
| Height | 13.4 mm / 0.528 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Mounting type | Mounting flange |
| Number of Poles | 14 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 14 |
| Total number of potentials | 14 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 12.198 г |
| Ширина | 63.8 mm / 2.512 inch |
Серия: 734 (100 из 708)
- 734-302/019-000 734-302/109-000 734-303 734-303/018-000 734-303/019-000 734-303/109-000 734-304 734-304/018-000 734-304/019-000 734-304/109-000 734-305 734-305/018-000 734-305/019-000 734-305/033-000 734-305/109-000 734-306 734-306/018-000 734-306/019-000 734-306/109-000 734-307 734-307/018-000 734-307/019-000 734-307/033-000 734-307/109-000 734-308 734-308/018-000 734-308/019-000 734-308/109-000 734-309 734-309/018-000 734-309/019-000 734-309/109-000 734-310 734-310/018-000 734-310/019-000 734-310/109-000 734-311 734-311/018-000 734-311/019-000 734-311/109-000 734-312 734-312/018-000 734-312/019-000 734-312/109-000 734-313 734-313/018-000 734-313/019-000 734-313/109-000 734-314 734-314/018-000 734-314/019-000 734-314/109-000 734-316 734-316/018-000 734-316/019-000 734-316/109-000 734-318 734-318/018-000 734-318/019-000 734-318/109-000 734-320 734-320/018-000 734-320/019-000 734-320/109-000 734-324 734-324/018-000 734-324/019-000 734-324/109-000 734-326 734-327 734-328 734-329 734-332 734-332/018-000 734-332/019-000 734-333 734-333/018-000 734-333/019-000 734-334 734-334/018-000 734-334/019-000 734-335 734-335/018-000 734-335/019-000 734-336 734-336/018-000 734-336/019-000 734-338 734-338/018-000 734-338/019-000 734-339 734-339/018-000 734-339/019-000 734-340 734-340/018-000 734-340/019-000 734-340/034-000 734-342 734-342/018-000 734-342/019-000
734314/019000, 734 314/019 000
