Datasheet Wago 734-367 — Даташит
2-conductor combi strip; 100% защита от неправильного подсоединения; 1,5; Шаг контактов 3,5 мм; 7-пол.
2-CONDUCTOR COMBI STRIP; 100% PR | |||
| 734-367 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | light gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Distribution connectors |
| Country of origin | PL |
| Габариты: глубина | 40.9 mm / 1.61 inch |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
| Fire load | 0.26 MJ |
| GTIN | 4045454214555 |
| Height | 18.5 mm / 0.728 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 7 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
| Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
| Total number of connection points | 14 |
| Total number of potentials | 7 |
| Вес | 16.908 г |
| Ширина | 27.35 mm / 1.077 inch |
Серия: 734 (100 из 708)
- 734-336 734-336/018-000 734-336/019-000 734-338 734-338/018-000 734-338/019-000 734-339 734-339/018-000 734-339/019-000 734-340 734-340/018-000 734-340/019-000 734-340/034-000 734-342 734-342/018-000 734-342/019-000 734-344 734-344/018-000 734-344/019-000 734-345 734-345/018-000 734-345/019-000 734-346 734-346/018-000 734-346/019-000 734-346/019-000/035-000 734-348 734-348/018-000 734-348/019-000 734-349 734-349/018-000 734-349/019-000 734-350 734-350/018-000 734-350/019-000 734-362 734-362/008-000 734-362/037-000 734-363 734-363/008-000 734-363/037-000 734-364 734-364/008-000 734-364/037-000 734-365 734-365/008-000 734-365/037-000 734-366 734-366/008-000 734-366/037-000 734-367 734-367/008-000 734-367/037-000 734-368 734-368/008-000 734-368/037-000 734-369 734-369/008-000 734-369/037-000 734-370 734-370/008-000 734-370/037-000 734-371 734-371/008-000 734-371/037-000 734-372 734-372/008-000 734-372/037-000 734-400 734-402 734-402/001-000 734-403 734-403/001-000 734-404 734-404/001-000 734-405 734-405/001-000 734-406 734-406/001-000 734-407 734-407/001-000 734-408 734-408/001-000 734-409 734-409/001-000 734-410 734-410/001-000 734-412 734-412/001-000 734-420 734-426 734-427 734-428 734-429 734-430 734-431 734-432 734-432/001-000 734-433 734-433/001-000
