Datasheet Wago 734-371/008-000 — Даташит
Серия734
Модель734-371/008-000
2-conductor combi strip; 100% защита от неправильного подсоединения; Монтажные ножки; 1,5; Шаг контактов 3,5 мм; 11-пол.
Actuation typeOperating tool
Цветlight gray
Contact materialCopper alloy
Contact platingtin-plated
Contact type (pluggable connector)Distribution connectors
Country of originPL
Габариты: глубина40.9 mm / 1.61 inch
Fine-stranded conductor0.08 … 1.5 mm² / 28 … 14 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 1.5 mm²
Fire load0.402 MJ
GTIN4045454944377
Gehäuseblechstärke0.6 … 1.2 mm / 0.024 … 0.047 inch
Height23 mm / 0.906 inch
Height from the surface18.5 mm / 0.728 inch
Material groupI
Mismating protectionYes
Mounting typeSnap-in mounting foot
Number of Poles11
Number of connection types1
Number of levels1
Rated current10 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)160 В
Solid conductor0.08 … 1.5 mm² / 28 … 14 AWG
Strip length6 … 7 mm / 0.24 … 0.28 Inch
Total number of connection points22
Total number of potentials11
Type of mountingPanel mounting
Вес26.358 г
Ширина41.35 mm / 1.628 inch
734371/008000, 734 371/008 000
На английском языке: Datasheet Wago 734-371/008-000
