Datasheet Wago 734-403/001-000 — Даташит
Двухуровневая вилка THT; 1.0 x 1.0 mm solder pin; угловые; 100% защита от неправильного подсоединения; Шаг контактов 3,5 мм; 6-пол.
|  Купить 734-403/001-000 на РадиоЛоцман.Цены — от 505 до 1 843 ₽ 11 предложений от 4 поставщиков HDR MALE DBL-DECK 6POS | |||
| 734-403/001-000 Wago | от 505 ₽ | ||
| 734-403/001-000 | от 524 ₽ | ||
| 734-403/001-000 Wago | 1 843 ₽ | ||
| 734-403/001-000 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 21.8 mm / 0.858 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fire load | 0.074 MJ |
| GTIN | 4044918872867 |
| Height | 26.6 mm / 1.047 inch |
| Height from the surface | 23 mm / 0.906 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mismating protection | Yes |
| Number of Poles | 6 |
| Number of levels | 2 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 3.6 мм |
| Total number of potentials | 6 |
| Вес | 3.866 г |
| Ширина | 12.9 mm / 0.508 inch |
Серия: 734 (100 из 708)
- 734-346 734-346/018-000 734-346/019-000 734-346/019-000/035-000 734-348 734-348/018-000 734-348/019-000 734-349 734-349/018-000 734-349/019-000 734-350 734-350/018-000 734-350/019-000 734-362 734-362/008-000 734-362/037-000 734-363 734-363/008-000 734-363/037-000 734-364 734-364/008-000 734-364/037-000 734-365 734-365/008-000 734-365/037-000 734-366 734-366/008-000 734-366/037-000 734-367 734-367/008-000 734-367/037-000 734-368 734-368/008-000 734-368/037-000 734-369 734-369/008-000 734-369/037-000 734-370 734-370/008-000 734-370/037-000 734-371 734-371/008-000 734-371/037-000 734-372 734-372/008-000 734-372/037-000 734-400 734-402 734-402/001-000 734-403 734-403/001-000 734-404 734-404/001-000 734-405 734-405/001-000 734-406 734-406/001-000 734-407 734-407/001-000 734-408 734-408/001-000 734-409 734-409/001-000 734-410 734-410/001-000 734-412 734-412/001-000 734-420 734-426 734-427 734-428 734-429 734-430 734-431 734-432 734-432/001-000 734-433 734-433/001-000 734-434 734-434/001-000 734-435 734-435/001-000 734-436 734-436/001-000 734-437 734-437/001-000 734-438 734-438/001-000 734-439 734-439/001-000 734-440 734-440/001-000 734-442 734-442/001-000 734-462 734-462/037-000 734-463 734-463/037-000 734-464 734-464/037-000
734403/001000, 734 403/001 000
