Datasheet Wago 734-484 — Даташит
Розетка под пайку THT; 0.9 x 0.9 mm solder pin; прямые; 100% защита от неправильного подсоединения; Шаг контактов 3,5 мм; 24-пол.
| THT FEMALE HEADER; 0.9 X 0.9 MM | |||
| 734-484 Wago | по запросу | ||
| Цвет | light gray |
| Connector connection type | for PCBs |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 10.5 mm / 0.413 inch |
| Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
| Fire load | 0.195 MJ |
| GTIN | 4045454000035 |
| Height | 18.5 mm / 0.728 inch |
| Height from the surface | 14.7 mm / 0.579 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | Yes |
| Number of Poles | 24 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 3.5 mm (0.138 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 10 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 160 В |
| Solder pin arrangement | over the entire female connector, in line |
| Solder pin dimensions | 0.9 x 0.9 mm |
| Solder pin length | 3.8 мм |
| Total number of connection points | 24 |
| Total number of potentials | 24 |
| Вес | 12.83 г |
| Ширина | 85.5 mm / 3.366 inch |
Серия: 734 (100 из 708)
- 734-433 734-433/001-000 734-434 734-434/001-000 734-435 734-435/001-000 734-436 734-436/001-000 734-437 734-437/001-000 734-438 734-438/001-000 734-439 734-439/001-000 734-440 734-440/001-000 734-442 734-442/001-000 734-462 734-462/037-000 734-463 734-463/037-000 734-464 734-464/037-000 734-465 734-465/037-000 734-466 734-466/037-000 734-467 734-467/037-000 734-468 734-468/037-000 734-469 734-469/037-000 734-470 734-470/037-000 734-471 734-471/037-000 734-472 734-472/037-000 734-473 734-473/037-000 734-474 734-474/037-000 734-476 734-476/037-000 734-478 734-478/037-000 734-480 734-480/037-000 734-484 734-484/037-000 734-502 734-502/037-000 734-503 734-503/037-000 734-504 734-504/037-000 734-505 734-505/037-000 734-506 734-506/037-000 734-508 734-508/037-000 734-509 734-509/037-000 734-510 734-510/037-000 734-512 734-512/037-000 734-514 734-514/037-000 734-515 734-515/037-000 734-516 734-516/037-000 734-520 734-520/037-000 734-532 734-532/037-000 734-533 734-533/037-000 734-534 734-534/037-000 734-535 734-535/037-000 734-536 734-536/037-000 734-537 734-537/037-000 734-538 734-538/037-000 734-539 734-539/037-000 734-540 734-540/037-000 734-541 734-541/037-000 734-542 734-542/037-000
