Datasheet Wago 734-520/037-000 — Даташит
Розетка под пайку THT; 0.9 x 0.9 mm solder pin; прямые; 100% защита от неправильного подсоединения; Фиксирующий рычаг; Шаг контактов 3,81 мм; 20-пол.
![]() 17 предложений от 10 поставщиков Ручной/электрический инструмент, Crimp Tool | |||
734520-1 TE Connectivity | 53 471 ₽ | ||
734520-1 TE Connectivity | от 58 289 ₽ | ||
734-520 Wago | по запросу | ||
734520-1 TE Connectivity | по запросу |
Цвет | orange |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 10.5 mm / 0.413 inch |
Drilled hole diameter (tolerance) | 1.4(+ 0.1) мм |
Fire load | 0.232 MJ |
GTIN | 4045454120559 |
Height | 18.5 mm / 0.728 inch |
Height from the surface | 14.7 mm / 0.579 inch |
Locking of plug-in connection | locking lever |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | Yes |
Number of Poles | 20 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 3.81 mm (0.15 inch) |
Rated current | 10 A |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.9 x 0.9 mm |
Solder pin length | 3.8 мм |
Total number of connection points | 20 |
Total number of potentials | 20 |
Вес | 12.4 г |
Ширина | 88 mm / 3.465 inch |
Серия: 734 (100 из 708)
- 734-466/037-000 734-467 734-467/037-000 734-468 734-468/037-000 734-469 734-469/037-000 734-470 734-470/037-000 734-471 734-471/037-000 734-472 734-472/037-000 734-473 734-473/037-000 734-474 734-474/037-000 734-476 734-476/037-000 734-478 734-478/037-000 734-480 734-480/037-000 734-484 734-484/037-000 734-502 734-502/037-000 734-503 734-503/037-000 734-504 734-504/037-000 734-505 734-505/037-000 734-506 734-506/037-000 734-508 734-508/037-000 734-509 734-509/037-000 734-510 734-510/037-000 734-512 734-512/037-000 734-514 734-514/037-000 734-515 734-515/037-000 734-516 734-516/037-000 734-520 734-520/037-000 734-532 734-532/037-000 734-533 734-533/037-000 734-534 734-534/037-000 734-535 734-535/037-000 734-536 734-536/037-000 734-537 734-537/037-000 734-538 734-538/037-000 734-539 734-539/037-000 734-540 734-540/037-000 734-541 734-541/037-000 734-542 734-542/037-000 734-543 734-543/037-000 734-544 734-544/037-000 734-546 734-546/037-000 734-548 734-548/037-000 734-550 734-550/037-000 734-554 734-554/037-000 734-562 734-562/037-000 734-563 734-563/037-000 734-564 734-564/037-000 734-565 734-565/037-000 734-566 734-566/037-000 734-568 734-568/037-000 734-569 734-569/037-000 734-570
734520/037000, 734 520/037 000
